D2 - Interior Seats, dashboards, plastics, ventilation everything inside the cabin |
seat runners
Hi All,
My passenger seat runner is loose. It is only the rear screw which I think is a t40 or t45. I have the right socket/bit to fit, that is not the problem. The problem is that the bolt is not screwed right down tight and is a little loose, that is to say it will move from side to side, but it will not either tighten down or unscrew. Before I simply apply wd40 and brute force I wanted to know if there is anything I am missing or should be aware of...? Is there something under the carpet which holds it in place like some sort of locknut or split pin ? much appreciated. si
current: - newbie to audis, 2001 s8 purchased aug 2018, changes have begun... centre box delete and straight through pipes. - e9 csl 1972, fully restored, silly bits to finish - 2002tii 1972, 'bought by accident' and work in progress - toyota hiace camper, just repainted in gulf racing colours and now getting used - honda c90 custom cub, ' bought by accident'....there seems to be a them here..! (Not so) Recently departed: - very sadly sold to fund the e9....BMW e28 m535 white 1986, owned 12 years, I loved that car. - red mk1 vw golf gti, fully sorted: resprayed, flash red, mk2 1800 16v conversion, uprated brakes, shocks, leather interior, - 1986 Saab 900 turbo convertible sold to get Audi on 'one out, one in' rule imposed by missus...not really adhering to the rule at the moment as can be seen..! |
There's a captive nut under the floor. If you put too much force on the bolt the nut will tear out of its housing so be careful how much you heave on it. I would be inclined to see if it will come out first. The thread may be damaged so it could make it worse forcing it in. If the bolt is damaged then I'm sure our sponsors will have a few available.
