Go Back   A8 Parts Forum > A8 D4 > D4 - Sat Nav, ICE, Audio & TV
D4 - Sat Nav, ICE, Audio & TV All in car entertainment discussions including MMI 3G Plus
Old 3rd September 2018, 08:27 PM
Default How to check for MMI version?
I'm a long time MMI 2G user on my 2005 A8 but I'm looking for a replacement 3G+ Car.
I'm sure it's simple but I can't find where the version screen is on the enhanced MMI screen
Could someone please tell me how to check the version of the 3G+ MMI on these later cars?
Thanks - Julian
Later Edit: Now I've had a D4 for a couple of weeks, I find it is easy:
Hit 'Menu' button; select 'Top Right' button to get settings; scroll to bottom to select 'Version Information'
Old 4th September 2018, 06:11 AM
Easiest way to tell is if the MMI click wheel has an additional mini joystick on top. Reasonably obvious in photos if the resolution is good enough in an advert
I’m sure IT has posted about d3 differences and how to spot them before? I think early facelifts were still 2g?
Old 4th September 2018, 08:44 AM
Hi Adrian, thanks for your prompt reply.
But I was asking about the 3G+ system on the 2011-2017 cars and not the 3G update to 2G [the one with the joystick button].
Regards - Julian
Old 4th September 2018, 03:22 PM
I've got a feeling you go into this screen as if setting up clock etc and select "setup MMI" tab then the data is shown somewhere in there (but don't quote me on it I dont have a D4 here at the moment to check!
Name:	Setup MMi D4.jpg
Old 4th September 2018, 03:37 PM
Ah sorry, didn't pick up on the distinction - on my B8 S5 it's 3G and then on B8.5 it's 3GP or 3G+ so easy to tell as all later cars have the later MMI system, and thought your query was in the D3 section - d'oh!.
The levels of firmware I'm aware of for the D4 A8 are:
P0066 (P is for production so the later the car the later the firmware level prefaced by P)
K0097
K0485_18
K0518_7
K0612_8
K0614_1
K0783
K0900
I pulled these together for IT from stored files i have for map updates that require a particular level of firmware first, but as to where you find the info I'm not so sure.....it'll be with the map database update level too, so if it's not an obvious option under car - settings - version information, I'd be delving into the navigation menus in a bit more depth....
Sorry for potentially not being all that helpful
ETA - d'oh! At least Neil has provided a likely solution while I've been wasting my time on this lol
Old 4th September 2018, 04:51 PM
Thanks for your input guys; after 10 years experience of MMI 2G on my 2005 A8, it's frustrating to be a beginner again while I look at 2013/4 A8s
I found the version screen on an A8 in which I had a test drive today, but forget where it was for next time.
For info, think it was:
HN+_EU_AU3G_P0532_?
8R0060884AH ECE 5.13.8
This was an August 2012 car so I think this is probably what was on the car when new ...
Julian
Old 19th October 2018, 06:36 PM
GlynH GlynH is offline
The latest version I saw on my earlier 2011 car was K0942_4 which is newer than the P0770 I have on the 2014 car!
Despite the MMI software on the older car being newer (it had been updated by Audi Northampton in September 2017) the mapping was older showing 8R0060884ED ECE 6.24.2
After Audi Northampton performed half-an-update on the newer car in May this year I ended up with a newer mapping version 8R0060884FC ECE 6.26.1 but left with the older factory MMI software.
Coincidentally I just posted in another thread that Audi Northampton updated the 2011 car but wouldn't update my 2014...
-=Glyn=-
