Old 16th September 2018, 02:56 PM
NightOwl NightOwl is offline
Default Webasto won't fire, fuel or communication?
Noticed lately that the aux heater doesn't work and give error code in VCDS with "No Flame".
Totally get 3 errors for the Aux Heater:
01406 - No Flame
01336 - Company Data Bus for Comfort System - No signal/communication
01407 - Flame Extinguished
And one for the CAN Gateway
01207 Control Module for Auxiliary Heater - No Signal/Communication
I wonder if the 01336 and 01207 are related to one another, and are triggered because of the Webasto goes into lock and need to be reset/opened after "No Flame" error?
I've taken the Webasto out and apart, and everything looks fine. The glow plug measures 0,5 ohm, with the probes shortened 0,2 ohm, so should give about 0,3 something for the glow plug alone. From what I understand that should be okay?
Tried to test run the Webasto from the VCDS, while not connecting the fuel line, and everything seems to start and run as it should apart from that it obviously didn't fire. No diesel came from the fuel line, so I expect maybe the dosing pump to be faulty?
Question is, should I follow the communication errors, or are those related to not firing, or should I check the dosing pump?
The last question is, where is the dosing pump located? I've searched high and low online but can't find any information about it.
The car is a A8 2006 3.0TDI and the Webasto doesn't have a timer or remote.
2006 Audi A8 3.0 TDI Quattro Sport
A8 W12/S8 Brakes front and rear (385mm/335mm)
Focal and JBL speakers, Helix amps
S8 anti-roll bars front and rear
Complete rear LED taillight
Xenon fog lights
All interior LED
S8 rims 9x20"
Stage II tune
S8 Grill
Old 16th September 2018, 06:58 PM
jza8's Avatar
jza8 jza8 is offline
Dosing pump should be under the car near the fuel tank, it should click audibly when working, you should be able to run dosing pump seperately from vcds to check
2010 Audi A8 4.2 TDI
Old 16th September 2018, 08:47 PM
Thanks, I also think it is in the rear somewhere. Any idea of where in vcds I can test run only the dosing pump?
Xenon fog lights
All interior LED
S8 rims 9x20"
Stage II tune
S8 Grill
Old 16th September 2018, 09:01 PM
jza8's Avatar
I don't know where in VCDS exactly, but there must be an option - probably under output tests in aux. heat
I have used the function in webasto's own thermo test software - there was a function called fuel line prime which ran the dosing pump
Old 17th September 2018, 01:25 PM
I'm sure you can enable a pair of timers in the HVAC section of the instruments using VCDS, just a matter of turning them on using the coding, at leeast if you've got no remote then that may be better than nothing
Old 17th September 2018, 11:24 PM
http://forum.a8parts.co.uk/attachmen...4&d=1512576358
Old 18th September 2018, 11:26 AM
Not sure what Webasto heater is in the 8 but the cab heater type i have is an Airtop 5000. You can hear the fuel pump clicking when it's running. If it's not been run for a while it can take a few fire ups for it to actually start up. There is a filter in line too somewhere i would have thought. If it had the Webasto thermostat it flashes a fault code that relates to the problem. I downloaded a load of stuff for it from Butlertechnik, service, parts, fitting instructions ect
Old 19th September 2018, 05:31 AM
The full name is Webasto Thermo Top C.
Xenon fog lights
All interior LED
S8 rims 9x20"
Stage II tune
S8 Grill
Old 20th September 2018, 12:12 PM
This might help along with the 8 fitting guide
File Type: pdf Webasto_Heater_Thermo_Top_C_Workshop_Manual_(2).pdf (7.80 MB, 3629 views)
Old 2nd October 2018, 07:49 PM
roberto's Avatar
roberto roberto is offline
my A8 has one of these fitted
are they standard
and what does it do and when ?
