Old 23rd October 2018, 11:56 AM
Default "Rubber" seal between headlight and wing.
Today I noticed some damage to the sealing strip between the outer section (sidelight area) of the headlight unit and wing panel. Along the top edge, just outboard of the bonnet.
Part of the seal (an inch or so) has gone and the adjacent section appears to be coming loose.
Is this easy to replace, even available? Or would you just try and sort it out with careful application of black silicone sealant?
