Old 21st November 2018, 08:10 AM
Exerqtor Exerqtor is offline
Default Draining battery
Long time no see guys!
Have a little pickle going on now. Here the 11th now the car suddenly drained totally. I found out this when i was going to work on monday morning (ofc).
I hooked on the battery charger and took my spare car to work and used it for the reminder of the week with the A8L still charinging. Tried to start it this saturday and all seemed to bee good, drove it for a couple miles, let it stand still for 2-3 hours and took another drive, all ok. Put the car to rest at 10pm or something saturday night, and 2am saturday/sunday night the alarm started going of before it stoped totally again due to flat battery.
Hooked on the carger again and did a RMA on the battery (Sĝnnak 95ah AGM battery) and changed it yesterday at work 10am, did a battery coding + test. All good, and i drove the car home from work about 6pm and when i got up and tried to start it again today 6.45am ish it was totally dead again. So something draining like crasy.
Here's a full system search dump from when i changed the battery yesterday, noting that screams issues from what i can see!
It's a 2010 A8L 3.0 Quattro btw!
Tuesday,20,November,2018,10:10:58:10681
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2 (x64)
Data version: 20180927 DS296.0
www.Ross-Tech.com
Dealer/Shop Name: Veng Norge AS
Workshop Code: 790 33361 000070
VIN: WAUZZZ4E4AN004593 License Plate: AA65389
Mileage: 137590km-85494mi Repair Order:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 08 09 0E 0F 13 15 16 17 18 19 28 34 36 38 3C
42 46 47 4F 52 53 55 56 57 5C 5F 61 62 65 66 6C 72 76
VIN: WAUZZZ4E4AN004593 Mileage: 137590km-85494miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 1010
06-Seat Mem. Pass -- Status: Malfunction 1010
08-Auto HVAC -- Status: Malfunction 1010
09-Cent. Elect. -- Status: Malfunction 1010
0E-Media Player 1 -- Status: Malfunction 0010
0F-Digital Radio -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 1010
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 1010
19-CAN Gateway -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Malfunction 1010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Sporadic communication error 1000
38-Roof Electronics -- Status: Malfunction 1010
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 1010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Malfunction 1010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: Malfunction 0010
5C-Lane Maintain. -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Malfunction 1010
65-Tire Pressure -- Status: Malfunction 1010
66-Seat, Rear -- Status: Sporadic communication error 1000
6C-Back-up Cam. -- Status: Malfunction 1010
72-Door, Rear Right -- Status: Malfunction 1010
76-Park Assist -- Status: Malfunction 1010
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4E0 910 402 G HW: 4E0 907 401 D
Component: 3.0L V6TDI A000AG 0030
Revision: --H05--- Serial number: AUX3Z0IN370124
Coding: 0011773
Shop #: WSC 80093 222 69422
VCID: 2045E342F3EA5A4AF5-8074
2 Faults Found:
005660 - Glowplug for Cylinder 3 (Q12)
P161C - 001 - Open Circuit
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 134684 km
Time Indication: 0
Date: 2018.07.02
Time: 15:06:34
Freeze Frame:
RPM: 882 /min
Torque: 132.6 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 12.69 V
Duty Cycle: 23.7 %
Temperature: 27.9°C
001378 - System Voltage
P0562 - 001 - Too Low - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 137574 km
Time Indication: 0
Date: 2018.11.12
Time: 00:02:30
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 7.83 V
Bin. Bits: 00110000
Temperature: 9.9°C
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E1 910 156 Q HW: 09L 927 156 A
Component: AG6 09L 3,0 TDI RdW 0020
Revision: --H01--- Serial number: 4467365
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 31631606A800E3C26A-8064
1 Fault Found:
049478 - No Communication with Diagnostic Gateway
U0146 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 7.0°C
T.B. Angle: 0.0°
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 J HW: 4E0 614 517 CP
Component: ESP 5.7 allrad H50 0540
Coding: 0007567
Shop #: WSC 38415 000 00000
VCID: 2A51016A85D6901AAB-807E
6 Faults Found:
00532 - Supply Voltage B+
000 - - - Intermittent
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
01299 - Diagnostic Interface for Data Bus (J533)
02083 - Message for Delay Request
01315 - Transmission Control Module
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 A
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0IN370124
Coding: 0410624
Shop #: WSC 02313 785 00200
VCID: 58B58BA2EB3AD28ACD-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
3 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 14
Reset counter: 59
Mileage: 137184 km
Time Indication: 0
Date: 2018.10.25
Time: 16:35:34
02072 - Control Module for Energy Management (J644)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 0
Reset counter: 57
Mileage: 137568 km
Time Indication: 0
Date: 2018.11.11
Time: 16:14:52
01336 - Company Data Bus for Comfort System
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 57
Mileage: 137568 km
Time Indication: 0
Date: 2018.11.11
Time: 16:19:10
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063968
VCID: 244DEF52E7F2466A91-8070
4 Faults Found:
01964 - Control Module for Seat & Steering Column Memory (J136)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Date: 2009.01.01
Time: 00:00:00
01733 - Switch for Head-Rest Adj. Pass. Seat (E170); Down
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 4
Fault Frequency: 40
Reset counter: 58
Mileage: 0 km
Time Indication: 0
Date: 2009.01.01
Time: 00:00:00
01732 - Switch for Head-Rest Adj. Pass. Seat (E170); Up
Freeze Frame:
Fault Priority: 4
Fault Frequency: 42
Reset counter: 58
Mileage: 0 km
Time Indication: 0
Date: 2009.01.01
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 58
Mileage: 137584 km
Time Indication: 0
Date: 2018.11.18
Time: 00:55:34
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 C HW: 4E0 820 043 L
Component: KLIMAAUTOMAT 017 0060
Revision: 00000037 Serial number: 00000000168705
Coding: 0329951
VCID: 1D3BDAB6C49877A2DE-8048
Subsystem 1 - Part No: 4E0 910 133
Component: FHS H03 0070
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Subsystem 3 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 4 - Serial number: 898053000
Subsystem 5 - Serial number: HO30102009065A000000000024˙†89
Subsystem 6 - Serial number: 000024˙†898053000 000-SHO
Subsystem 7 - Serial number: 000-SHO30102009065A00000000
Subsystem 8 - Serial number: 65A000000000066˙
2 Faults Found:
00066 - Rear Right Footwell Heater (Z43)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 19
Mileage: 134235 km
Time Indication: 0
Date: 2018.06.12
Time: 07:19:34
Freeze Frame:
Voltage: 11.00 V
00065 - Rear Left Footwell Heater (Z42)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 17
Mileage: 134235 km
Time Indication: 0
Date: 2018.06.12
Time: 07:19:35
Freeze Frame:
Voltage: 11.00 V
Address 09: Cent. Elect. Labels: 4E0-910-279.clb
Part No SW: 4E0 910 279 S HW: 4E1 955 113 C
Component: ILM Fahrer H16 0240
Coding: 0143122
VCID: 38752B224B7A328A2D-806C
Subsystem 1 - Part No: 4E1 910 113 C
Component: Wischer WWS D3 H60 0420
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00154972
Shop #: WSC 02313
5 Faults Found:
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Reset counter: 57
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 19
Reset counter: 57
Time Indication: 0
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:19:11
01520 - Rain and Light Recognition Sensor (G397)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 69
Reset counter: 58
Mileage: 137574 km
Time Indication: 0
Date: 2018.11.12
Time: 00:01:48
00908 - Control Module for Wiper Motor
Freeze Frame:
Fault Priority: 2
Fault Frequency: 25
Reset counter: 58
Mileage: 137574 km
Time Indication: 0
Date: 2018.11.12
Time: 00:01:48
Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 L HW: 4E0 035 110 A
Component: CDC-MP3-Pana H49 0050
Revision: 00000015
VCID: 2143E64638E05342FA-8074
2 Faults Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 5
Fault Frequency: 8
Reset counter: 58
Mileage: 137574 km
Time Indication: 0
Date: 2018.11.12
Time: 00:01:48
Freeze Frame:
Fault Priority: 7
Fault Frequency: 6
Reset counter: 40
Mileage: 137574 km
Time Indication: 0
Date: 2018.11.12
Time: 00:02:28
Address 0F: Digital Radio
Cannot be reached
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4E0 910 561 F HW: 4E0 907 561 F
Component: ABSTANDSREGELUNGH03 0020
Coding: 0031268
VCID: 254BF256ECC8BF6286-8070
2 Faults Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10111101
Fault Priority: 5
Fault Frequency: 4
Reset counter: 58
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.12
Time: 09:06:00
Freeze Frame:
Temperature: 5.0°C
Voltage: 10.88 V
Bin. Bits: 00100000
004 - No Signal/Communication - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10110100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 57
Time Indication: 0
Freeze Frame:
Temperature: 5.0°C
Voltage: 10.24 V
Bin. Bits: 11100000
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 E HW: 4E0 959 655 K
Component: Airbag 9.41 H01 4210
Revision: 91H01421 Serial number: 003CU000VYBZ
Coding: 0431705
VCID: 2855FB629BDAA20ABD-807C
Subsystem 1 - Serial number: 63328RB4051FD878Z
Subsystem 2 - Serial number: 63428RB4051FD8A7
Subsystem 3 - Serial number: 63528RB4051FD951T
Subsystem 4 - Serial number: 63628RB4051FDA97+
Subsystem 5 - Serial number: 63729RB4048CED8CB
Subsystem 6 - Serial number: 63829RB4048CF239.
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 58
Mileage: 137574 km
Time Indication: 0
Date: 2018.11.12
Time: 00:00:57
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 B
Component: J0527 0530
Revision: 00H06000 Serial number: 90026092050069
Coding: 0032351
VCID: 2649F55A91CEB47A8F-8072
Component: E0221 H01 0030
8 Faults Found:
00456 - Control Module for Access and Start Control (J518)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 11
Reset counter: 58
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:10
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 58
Mileage: 137584 km
Time Indication: 0
Date: 2018.11.18
Time: 13:33:03
Freeze Frame:
Fault Priority: 6
Fault Frequency: 20
Reset counter: 58
Mileage: 137574 km
Time Indication: 0
Date: 2018.11.12
Time: 00:00:20
Freeze Frame:
Fault Priority: 4
Fault Frequency: 13
Reset counter: 58
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:10
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 58
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:10
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 7
Reset counter: 58
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:18
Freeze Frame:
Fault Priority: 4
Fault Frequency: 9
Reset counter: 58
Time Indication: 0
Date: 2063.15.31
Time: 31:63:48
Freeze Frame:
Fault Priority: 4
Fault Frequency: 8
Reset counter: 58
Time Indication: 0
Date: 2063.15.31
Time: 31:63:48
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 931 S HW: 4E0 920 931 S
Component: KOMBIINSTR. VDO H86 0640
Revision: D06 Serial number: AUDID3IN101416
Coding: 0048003
Shop #: WSC 30374 000 104857
VCID: 336F1C0E521CD1D218-8066
No fault code found.
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 265 081 AC
Component: Heizgeraet H08 0160
Revision: 0000000D Serial number: 00000009013887
Coding: 0000111
VCID: 1A31D1AAD5B6009A3B-804E
3 Faults Found:
34391 - Energy Management 2
Unknown - 004 - - Intermittent
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4E0 907 468 H
Component: J533__Gateway H06 0071
Revision: 00H06000 Serial number: 0300J09A018064
Coding: F5FDDF7F270EAE00
VCID: 2D5B0A76B43887224E-8078
20 Faults Found:
00461 - Control Module for Seat Memory; Passenger (J521)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Reset counter: 57
Mileage: 137566 km
Time Indication: 0
Date: 2018.11.11
Time: 15:52:59
00462 - Control Module for Seat Memory; Rear (J522)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:15
01332 - Door Control Module; Passenger Side (J387)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:11
01333 - Door Control Module; Rear Left (J388)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:11
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:11
01331 - Door Control Module; Driver Side (J386)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:11
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:11
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:11
01308 - Control Module for Roof Electronics (J528)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 19
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:11
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:11
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:11
00565 - Rear A/C Control Head (Climatronic) (E265)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 13
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:12
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 13
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:12
01207 - Control Module for Auxiliary Heater (J364)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:12
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:12
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:14
01327 - Control Module for Parking Aid (J446)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:14
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:14
02103 - Control Module 2 for Vehicle Electrical System (J520)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:14
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:14
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 A HW: 4E0 919 158 G
Component: KLIMA-STG. FOND 017 0240
Revision: 00000022 Serial number: 00000000086798
Coding: 0000000
VCID: 2241E94AFDE6485AE3-8076
1 Fault Found:
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 K HW: 4E0 907 553 H
Component: LUFTFDR.-CDC H07 4590
Coding: 0015510
Shop #: WSC 30545 000 104857
VCID: 2B5F046E8A2C891250-807E
2 Faults Found:
01398 - Signal Conductor for Central Locking; Doors Open
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 21
Mileage: 137199 km
Time Indication: 0
Date: 2018.10.26
Time: 15:03:21
01598 - Drive Battery Voltage
Freeze Frame:
Fault Status: 11100010
Fault Priority: 4
Fault Frequency: 7
Reset counter: 19
Mileage: 137574 km
Time Indication: 0
Date: 2018.11.12
Time: 00:00:26
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4063978
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H05 0090
Serial number: 00000929600101
Coding: 0069030
5 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 11
Reset counter: 58
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.12
Time: 06:45:00
00308 - Supply Voltage for Motors for Sunroof/sunroof Shade
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.12
Time: 06:45:00
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0040
Revision: 00H01000 Serial number: 6PZ 009 014-10
Coding: 0000108
VCID: 2E590D7AB93EFC3A77-807A
Subsystem 1 - Part No: 4L0 910 568 C
Component: J0770_SWA_Slave_H01 0040
Subsystem 2 - Serial number: 6PZ 009 014-30
Subsystem 3 - Serial number: 5F06.11.0900H010003C911005˙
Subsystem 4 - Serial number: 911005˙
2 Faults Found:
02857 - Supply Voltage for Lane Change Assistance Control Module 2
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.12
Time: 00:00:16
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.12
Time: 00:00:16
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 F
Component: Türsteuer.FS BRM005 0180
Coding: 0032749
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 57
Mileage: 137568 km
Time Indication: 0
Date: 2018.11.11
Time: 16:15:08
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 57
Mileage: 137568 km
Time Indication: 0
Date: 2018.11.11
Time: 16:19:22
02111 - Motor for Window Regulator
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 58
Mileage: 137568 km
Time Indication: 0
Date: 2018.11.12
Time: 00:01:30
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 58
Mileage: 137568 km
Time Indication: 0
Date: 2018.11.12
Time: 00:01:30
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 E HW: 4E0 907 289 E
Component: Komfortgeraet H11 0040
Revision: 00400011 Serial number: W040911110185
Coding: 0004728
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P27H08 0090
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H05 0020
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:14:55
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:15:30
Address 47: Sound System (J525) Labels: None
Part No SW: 4E0 035 466 E HW: 4E0 035 466 C
Component: BO D3 H08 0120
Revision: 52S00002 Serial number: 02508090015748
Coding: 0D000100
Shop #: WSC 02399 823 56573
VCID: 2649F55A51CEB47A8F-8072
Subsystem 1 - Part No SW: 4E0 910 465 B HW: 4E0 035 465
Component: BO D3 SLAVE H31 0310
Serial number: 02809090011792
7 Faults Found:
03278 - Functionality Limited due to Missing Messages
Freeze Frame:
Fault Priority: 6
Fault Frequency: 14
Reset counter: 57
Time Indication: 0
Freeze Frame:
Voltage: 13.40 V
Temperature: 4.0°C
Bin. Bits: 00000011
Voltage: 13.50 V
Temperature: 12.0°C
Bin. Bits: 01110010
Bin. Bits: 00000000
03454 - Functional Restriction due to Implausible Signal
Freeze Frame:
Fault Priority: 6
Fault Frequency: 11
Reset counter: 57
Mileage: 130758 km
Time Indication: 0
Date: 2017.11.30
Time: 15:50:12
Freeze Frame:
Voltage: 13.30 V
Temperature: 4.0°C
Bin. Bits: 00000100
Voltage: 13.50 V
Temperature: 12.0°C
Bin. Bits: 00000000
Bin. Bits: 00100000
03455 - Function Restriction due to Faults in Other Modules
Freeze Frame:
Fault Priority: 6
Fault Frequency: 15
Reset counter: 57
Mileage: 130758 km
Time Indication: 0
Date: 2017.11.30
Time: 15:50:12
Freeze Frame:
Voltage: 13.30 V
Temperature: 5.0°C
Bin. Bits: 00000100
Voltage: 13.50 V
Temperature: 12.0°C
Bin. Bits: 10000000
Bin. Bits: 00001110
03028 - Fan for Digital Sound System Control Module 2 (V374)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 3
Reset counter: 18
Mileage: 137156 km
Time Indication: 0
Date: 2018.10.24
Time: 06:47:45
Freeze Frame:
Voltage: 10.90 V
Temperature: -4.0°C
Bin. Bits: 00000100
Voltage: 11.00 V
Temperature: 2.0°C
Bin. Bits: 00000000
Bin. Bits: 00000000
Freeze Frame:
Fault Priority: 7
Fault Frequency: 9
Reset counter: 58
Mileage: 131540 km
Time Indication: 0
Date: 2018.01.27
Time: 18:53:55
Freeze Frame:
Voltage: 8.80 V
Temperature: 10.0°C
Bin. Bits: 00000100
Voltage: 9.00 V
Temperature: 20.0°C
Bin. Bits: 00000000
Bin. Bits: 00000000
02095 - Component Protection Active
Freeze Frame:
Fault Priority: 4
Fault Frequency: 9
Reset counter: 59
Mileage: 137199 km
Time Indication: 0
Date: 2018.10.26
Time: 15:16:56
Freeze Frame:
Voltage: 11.60 V
Temperature: 20.0°C
Bin. Bits: 00000100
Voltage: 11.50 V
Temperature: 30.0°C
Bin. Bits: 00000000
Bin. Bits: 00000000
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 58
Mileage: 137584 km
Time Indication: 0
Date: 2018.11.17
Time: 23:12:04
Freeze Frame:
Voltage: 8.70 V
Temperature: 27.0°C
Bin. Bits: 00000100
Voltage: 8.50 V
Temperature: 43.0°C
Bin. Bits: 10000101
Bin. Bits: 00000000
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 D
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000040775
Coding: 0010111
VCID: 1E39DDBAC99E6CBAC7-804A
Subsystem 1 - Part No: 8K0 907 410
Component: EHL205.06.02KHV H02 0010
Subsystem 2 - Serial number: 1451557T0YQL01
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:00
Freeze Frame:
Fault Status: 00110010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 58
Mileage: 137584 km
Time Indication: 0
Date: 2018.11.18
Time: 13:34:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:14:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 43
Reset counter: 58
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.12
Time: 00:01:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 F
Component: Türsteuer.BF BRM005 0180
Coding: 0032749
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 57
Mileage: 137568 km
Time Indication: 0
Date: 2018.11.11
Time: 16:15:08
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 57
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 58
Mileage: 137568 km
Time Indication: 0
Date: 2018.11.12
Time: 00:01:30
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 58
Mileage: 137568 km
Time Indication: 0
Date: 2018.11.12
Time: 00:01:30
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000221
Shop #: WSC 00011 888 96745
5 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 58
Time Indication: 0
Freeze Frame:
Voltage: 8.70 V
Count: 243
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 58
Time Indication: 0
Freeze Frame:
Voltage: 7.45 V
Count: 200
00576 - Terminal 15
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 58
Time Indication: 0
Freeze Frame:
Voltage: 8.07 V
Count: 41
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 58
Time Indication: 0
Freeze Frame:
Voltage: 8.70 V
Count: 247
02438 - Left Parking Brake Motor Hall Sensor
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11110100
Fault Priority: 4
Fault Frequency: 15
Reset counter: 97
Mileage: 134560 km
Time Indication: 0
Date: 2018.06.27
Time: 14:44:33
Freeze Frame:
Voltage: 13.15 V
Count: 94
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0060
Revision: 00000001 Serial number:
Coding: 0000018
VCID: 69D3BE6640505B0262-803C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 17
Mileage: 137201 km
Time Indication: 0
Date: 2018.10.26
Time: 17:35:36
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 17
Mileage: 137574 km
Time Indication: 0
Date: 2018.11.12
Time: 00:02:28
Address 56: Radio
Cannot be reached
Address 57: TV Tuner (R78) Labels: None
Part No SW: 4F0 919 129 C HW: 4F0 919 129
Component: HybridTV-DVB H06 0390
Revision: R0060000 Serial number: 76300802506702
Coding: 01010000
VCID: 2C5D07724F228E2A59-8078
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 58
Mileage: 137584 km
Time Indication: 0
Date: 2018.11.18
Time: 00:55:41
Address 5C: Lane Maintain. Labels: None
Part No SW: 4E0 910 217 C HW: 4E0 907 217 C
Component: J759 LDW H07 0070
Revision: 00H07018 Serial number: 800209B030000C
Coding: 0001004
3 Faults Found:
02797 - Control Module for Directional Stabilization Assistance (J759)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 3
Reset counter: 40
Mileage: 134283 km
Time Indication: 0
Date: 2018.06.14
Time: 15:55:00
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 57
Time Indication: 0
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 57
Mileage: 137574 km
Time Indication: 0
Date: 2018.11.12
Time: 00:00:19
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4E0 035 666 C HW: 4E0 035 666 C
Component: H-BN-EU H47 0047
Revision: -------- Serial number: 454B+0A7538972
Coding: 010100000000FBEFD8001315FF7F00030001
Shop #: WSC 38415 123 999999
Subsystem 1 - Part No: 8R0 060 884 J
Component: EUR 2010 1005
Subsystem 2 - Part No SW: 4E0 919 604 A HW: 4E0 919 604 A
Component: DU7 High Alu H43 0306
Serial number: 9357KU091003619
Subsystem 3 - Part No SW: 4E0 910 611 HW: 4E1 919 612 N
Component: E0380 Bedient H01 0050
Serial number: 00000000086819
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
4 Faults Found:
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 133
Reset counter: 59
Mileage: 134268 km
Time Indication: 0
Date: 2018.06.13
Time: 15:34:38
Freeze Frame:
Voltage: 12.60 V
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 19
Mileage: 137591 km
Time Indication: 0
Date: 2018.11.20
Time: 10:03:35
Freeze Frame:
Bin. Bits: 00000000 00100000
Bin. Bits: 00000000 00000000
03367 - Supply Voltage for Display Module
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 58
Mileage: 137584 km
Time Indication: 0
Date: 2018.11.18
Time: 13:27:53
Freeze Frame:
Voltage: 8.30 V
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:13:59
Freeze Frame:
Bin. Bits: 00000000 00000010
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000006409
Shop #: WSC 30538 000 1048576
Subsystem 1 - Part No: 4E0 915 105 A
Component: von TU3 31110440UX
Coding: 344530393135313035412054553333313131303434305558
Shop #: WSC 38415 123 82814
5 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 58
Mileage: 137584 km
Time Indication: 0
Date: 2018.11.18
Time: 00:55:33
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 58
Mileage: 137584 km
Time Indication: 0
Date: 2018.11.19
Time: 22:43:24
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:19:11
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:19:11
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:19:11
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0032749
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 57
Mileage: 137568 km
Time Indication: 0
Date: 2018.11.11
Time: 16:19:22
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 58
Mileage: 137568 km
Time Indication: 0
Date: 2018.11.12
Time: 00:01:28
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 58
Mileage: 137568 km
Time Indication: 0
Date: 2018.11.12
Time: 00:01:28
02605 - Control Module for Side Blinds (J719)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 58
Mileage: 0 km
Time Indication: 0
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000700061907
Coding: 0212727
5 Faults Found:
Freeze Frame:
Fault Status: 10100100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Freeze Frame:
(no units): 0.0
Voltage: 0.00 V
(no units): 33.0
Temperature: 0.0°C
Temperature: 0.0°C
Temperature: 0.0°C
Temperature: 0.0°C
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 57
Mileage: 137574 km
Time Indication: 0
Date: 2018.11.12
Time: 00:00:32
Freeze Frame:
(no units): 255.0
Voltage: 0.00 V
(no units): 27.0
Temperature: 0.0°C
Temperature: 7.0°C
Temperature: 0.0°C
Temperature: 7.0°C
01325 - Control Module for Tire Pressure Monitoring (J502)
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 253
Reset counter: 0
Mileage: 137584 km
Time Indication: 0
Date: 2018.11.19
Time: 17:18:33
Freeze Frame:
(no units): 0.0
Temperature: 1.0°C
Error Code: 4
Pressure: 2.30 bar
Pressure: 2.05 bar
Pressure: 2.30 bar
Pressure: 2.27 bar
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 57
Mileage: 0 km
Time Indication: 0
Freeze Frame:
(no units): 0.0
Voltage: 0.00 V
(no units): 26.0
Temperature: 0.0°C
Temperature: 0.0°C
Temperature: 0.0°C
Temperature: 0.0°C
01521 - Sensor for Tire Pressure
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 36
Mileage: 137372 km
Time Indication: 0
Date: 2018.11.02
Time: 15:23:44
Freeze Frame:
(no units): 12.0
Temperature: 10.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 66: Seat, Rear Labels: None
Part No SW: 4E0 910 860 HW: 4E0 959 860
Component: Sitz Fond H06 0050
Revision: 00000000 Serial number: 5DS 008 795-01
Coding: 0000502
Shop #: WSC 15981 001 1048576
VCID: 61C3A646B8601342BA-8034
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J9X109C
Coding: 1020503
VCID: 5CBD97B29F023EAAE9-8008
6 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 50
Reset counter: 57
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:10
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 37
Reset counter: 57
Time Indication: 0
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 57
Time Indication: 0
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 57
Time Indication: 0
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 58
Mileage: 137584 km
Time Indication: 0
Date: 2018.11.18
Time: 00:54:37
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 4
Fault Frequency: 6
Reset counter: 58
Mileage: 137574 km
Time Indication: 0
Date: 2018.11.12
Time: 00:00:12
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0032749
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 57
Mileage: 137568 km
Time Indication: 0
Date: 2018.11.11
Time: 16:19:22
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 58
Mileage: 137568 km
Time Indication: 0
Date: 2018.11.12
Time: 00:01:28
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 58
Mileage: 137568 km
Time Indication: 0
Date: 2018.11.12
Time: 00:01:28
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 58
Mileage: 0 km
Time Indication: 0
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 D HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0050
Revision: 00H12000 Serial number: 11030929900412
Coding: 0221008
4 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 57
Mileage: 137574 km
Time Indication: 0
Date: 2018.11.12
Time: 00:00:19
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 57
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 99
Reset counter: 40
Mileage: 137572 km
Time Indication: 0
Date: 2018.11.11
Time: 16:11:10
End-------------------------(Elapsed Time: 04:00)--------------------------
2010 D3 A8L 3.0 TDI QUATTRO
BI-Xenon Headlights, Keyless, Bang&Olufsen, DTV, DAB, Rear Camera, BT, TPMS, Soft Close, Auto Boot, AMI, 4 Zone AC, Home Link, All Electric Blinds, Ski Hatch, Black Extended Leather, Seat Memory on Both Sides, Heated / Cooled Sport Front Seats, Electrically Adjustable Rear & Heated Rear Seats Alacantra roofliner, Exterior LED Package, Lane Assist, Adaptive Cruise Control & Heated Steeringwheel ++.
Old 21st November 2018, 08:38 AM
You really need to clear all codes (global clear plus go into each module and physically clear as well) and then scan again as a lot of these codes are older codes. Once you have done that then re-post the fault codes fresh
Old 21st November 2018, 08:52 AM
Yeah i did that after i installed the new battery. Didn't have time to take a new readout today though.
The only things who were left after i deleted them yesterday was the left parking brake motor (that's in is inbound, been defect a couple month's). And a couple others that should have anything to do with the drain.
But anyway's i can't see anything it that big list from the other day that indicates a failure right before the different systems started putting low voltage errors.
Old 28th November 2018, 08:16 AM
Ok, so update time. Haven't had time to f-around with the car before now. And i just swaped out the battery for a fully charged one and coded it.
I've had the car in the workshop for about 3 hours now with the ignition off, doors closed and truck shut (lights off). And i see that the ligthing in the shifter console, and all the backlighting in the roof panels are on (including the little white "spot" diodes in the rearview mirror).
Have anyone experienced this before?
Old 28th November 2018, 11:18 AM
Done a complete readout, deleted with CAN command, and then went in to each system and manually deleted what was left. Then did a new search, this is what i'm left with now (the parking break motor i'm going to change today, and tyre pressure is because of a leaky valve so i have those sorted) and i'm pretty sure the "00778 - Steering Angle Sensor (G85)" is because i haven't driven the car after i deleted the other codes / ie. not initialized yet.
Wednesday,28,November,2018,13:13:51:10681
www.Ross-Tech.com
Mileage: 137610km-85506mi Repair Order:
VIN: WAUZZZ4E4AN004593 Mileage: 137610km-85506miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
5C-Lane Maintain. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
66-Seat, Rear -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Coding: 0011773
Readiness: 0 0 1 1 1
Coding: 0000001
Coding: 0007567
1 Fault Found:
000 - -
Coding: 0410624
Component: ELV XXXX
Coding: 4063968
Coding: 0329951
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 20
Mileage: 137591 km
Time Indication: 0
Date: 2018.11.20
Time: 10:12:35
Freeze Frame:
Voltage: 11.30 V
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 19
Mileage: 137591 km
Time Indication: 0
Date: 2018.11.20
Time: 10:12:36
Freeze Frame:
Voltage: 11.30 V
Coding: 0143122
Coding: 00000036
Shop #: WSC 02313
Coding: 00154972
Shop #: WSC 02313
Revision: 00000015
Cannot be reached
Coding: 0031268
1 Fault Found:
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11111101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 20
Mileage: 137608 km
Time Indication: 0
Date: 2018.11.28
Time: 05:38:00
Freeze Frame:
Temperature: 26.0°C
Voltage: 11.39 V
Bin. Bits: 00100000
Coding: 0431705
Coding: 0032351
Coding: 0048003
Coding: 0000111
Coding: 0000000
Coding: 0015510
Coding: 4063978
Coding: 0069030
Coding: 0000108
Coding: 0032749
Coding: 0004728
Coding: 0D000100
Coding: 0010111
Coding: 0032749
Revision: --H03---
Coding: 0000221
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 15
Reset counter: 97
Mileage: 134560 km
Time Indication: 0
Date: 2018.06.27
Time: 14:44:33
Freeze Frame:
Voltage: 13.15 V
Count: 94
Coding: 0000018
Address 56: Radio
Cannot be reached
Coding: 01010000
Coding: 0001004
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 20
Mileage: 137610 km
Time Indication: 0
Date: 2018.11.28
Time: 05:40:10
Freeze Frame:
Component: von TU3 0738281118
Coding: 000001393135313035434654553330373338323831313138
Coding: 0032749
Coding: 0212727
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 20
Mileage: 137610 km
Time Indication: 0
Date: 2018.11.28
Time: 05:40:36
Freeze Frame:
(no units): 0.0
Temperature: 18.0°C
Error Code: 4
Pressure: 2.45 bar
Pressure: 2.15 bar
Pressure: 2.45 bar
Pressure: 2.45 bar
Coding: 0000502
Coding: 1020503
1 Fault Found:
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
Mileage: 137610 km
Time Indication: 0
Date: 2018.11.28
Time: 05:40:59
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Coding: 0032749
Coding: 0221008
End-------------------------(Elapsed Time: 03:44)--------------------------
Old 28th November 2018, 12:05 PM
The rear footwell heaters apparently are a common fault. As for the reversing camera fault, it seems tied into the steering angle sensor, so hopefully that will also disappear after you drive it.
Old 28th November 2018, 12:13 PM
Yup the rear footwell heater's is just something i totally ignore tbh
And i guess/hope that all faultcodes that i have there will go away when i change the parking brake motor and start to drive.
The problem ist still there in regards to draining the flipping battery though
Old 28th November 2018, 02:13 PM
The battery coding is showing null values at the start, but I would change them to zero's (coding is in HEX, therefore 30)
Code:
Try:
303030393135313035434654553330373338323831313138
and it's suggesting an Exide battery. I guess it's 110Ah?
That may solve nothing, just a but of house keeping making sure the BEM is happy and knows the capacity.
The fault code logged today, 2018.11.28, in the radar shows a voltage of 11.4v, which is too low. Have you charged it since then? Was this the old battery?
What's with the fault in both analogue and digital radios of can not be reached?
Is the car kept outside? The keyless door lock buttons can cause the car to keep waking up through water ingress or condense at the dew point.
Matt
Old 28th November 2018, 02:26 PM
Code:
Try:
It's a Sĝnnak SK1050 battery (105ah) i have in it that's fully carged with AGM mode, and tested with a Exide battery tester (outside of the car when fully charged) and it comes out ok.
The battery has been coded with a Exide battery coder to be a AGM 105 battery to, so i guess it should be ok?
The 11,4v is because i have been derping around with the VCDS (with charger on?). But somethings drawing it.
Regarding the radio fault codes is because i tryed to put in a 2013 Q5 radio unit to get DAB+, well over a year ago but it didn't work and i haven't gotten around fixing it. But the battery drain problem happened so long after i doubt that's the issue since it's been so long without any problems?
And yes the car is kept outside, but all the keyless buttons ( i'f you mean the ones that's on the chrome trim) all work? And no fault codes on them either?
I'm not saying there not the problem with what your mentioning ofc. just saying what i know atm :/ .
Old 29th November 2018, 05:06 AM
Swapped out the faulty parking brake motor yesterday, and redid the coding to 303030etc, drove the car home and had it standing over the night with charger on so that i can proceed with the car after work today.
Today i'm planing to update the MMI and navigation to see if that might help (ditch atempt, but it's needed anyways).
One thing that i find a little strange is that the clock in the instrument cluster still haven't adjusted itself? Even though it's had power (ignition off ofc) since 7pm ish yesterday and until now
