Old 13th May 2019, 05:03 PM
hunker7 hunker7 is offline
Default Single to double glazing
One of my window mechanisms is making weird noise. Because I only have 2.8 FWD could I upgrade to double glazing and would it need only the glass or the whole frame?
Old 13th May 2019, 06:17 PM
I'm planning on doing that to one of mine shortly. According to what I can find in Etka, the frame is the same, but the channel and the inner seal are different so you'd need a donor car to get everything. Prestige Motor Services took an A8 4.2 to bits recently so they may still have what you need.
Old 13th May 2019, 06:23 PM
We've done it in the past, but just swapped out the whole upper frames.
If you can get the guides separate, remove yours, and refit them perfectly, then you could do just the guides etc I guess but run the risk of it not quite going back nicely ?
Old 13th May 2019, 06:36 PM
Really don't want to be messing about, probably will be sourcing whole frame. Any idea on what it could cost me?
Old 13th May 2019, 08:17 PM
I had it done years ago on my first A8; also a 2.8. A8 Parts did it for me, so give them a call
Old 14th May 2019, 03:09 AM
Was there noticable difference?
Old 14th May 2019, 08:07 AM
Yes, because by mistake, they’d been so focussed on atching the glass colour, that 2 of the windows were still single glazed!. So you could here little or no wind and road noise through 2 windows and a noticable difference from the other two. They were brilliant about sorting that out thoughh, coming uo to Glasgow to collect my car and returning it a day or two later.
Old 14th May 2019, 09:20 AM
Wind noise is pretty bad compared to other cars I've driven, and can't see anything that could be causing it. Might just need put this on the list.
Old 14th May 2019, 09:47 AM
Its quite common for the upper door seals to shrink slightly leaving a gap at the top corner of the door, right by your ear. I adjusted mine when I had the doors in bits and it helped quite a lot. Possibly something to look at
Old 19th May 2019, 01:12 PM
This is how I've adjusted them to sit?
ID:	21638   Click image for larger version
