Old 13th May 2019, 06:52 PM
Rick Rick is offline
Default Starter relay.
Maybe not in the right section but im after some info on where the starter relay or relays or fuses lives in our s8 d3's.
Having a little problem of it not starting on the key.
If i bridge the connections on the solenoid it fires right up.
Is there a fuse or relay i can check between the ignition switch and starter? Mechanically the starter is sound as a pound. The solenoid could be buggered but im hoping its a little easier to fix than that!
Help greatly appreciated as its sitting on the drive going to waste!!
2006 S8 5.2 V10
