Old 2nd July 2019, 12:22 PM
oldnick oldnick is offline
Default removing tow ball
herewith an entry in the stupidest question of the year category
want to remove the ball .....factory fitted FL my2000
turn the plastic knob [ which locks the ball casting in place presumably ] , insert the tiny key , try clockwise and anticlockwise , try to pull down
nothing ...perhaps a tiny sideways movement
tried a second pair of hands ...still nothing
am I missing something ? a lump hammer on the ball didn't help !
Old 2nd July 2019, 12:58 PM
The key will only remove when locked - so, you can easily identify which position is unlocked.
Once unlocked, twist the black knob all the way round and it should drop out - if not, a gentle knock with a rubber mallet might pursuade it.
If its been in there a long time, you might be onto penetrating oils and more violence, but it should come out lol
So - Key in, unlock, then pull knob out slightly and twist it all the way round....
Old 2nd July 2019, 01:19 PM
thanks ian , will try again when I have working clothes on
didn't want to try brute force in case there was something I didn't realise !
i'ts only been on for a couple of years my farmer next door neighbour fitted it for me in his tractor workshop...he is used to such things !
Old 18th September 2019, 12:48 PM
all done !it was pulling the knob out after turning that I missed!
thanks again ian
