Old 6th July 2019, 08:15 AM
mannyo mannyo is offline
Default FS: Audi AMI KIT for MMI 2G
As I am in the process of selling my D3 and she maybe going in part exchange, I have removed my retrofitted AMI kit and as such the full kit is now here for sale.
You will get everything in the picture below.
Optical Splitter cable
Modified power cable, so that the AMI appears correctly on the Canbus and does not share the same device ID as the CD Changer which causes problems when using VCDS as it will flip flop between the changer and AMI if this cable is not used. You need to enable the second media player with VCDS in the installation list when using this cable.
The AMI module itself
and an AMI to USB cable, so you can play music from a USB stick or self powered laptop style HDD.
I cannot find the changer removal keys, but they are the usual Audi radio removal keys.
All in original Audi AMI box.
Price will be £310 plus postage ** Price updated **
This kit is MOST based, so will only work with the D3.
Manny
Past
