Old 3rd November 2019, 05:19 PM
irelandbuyer irelandbuyer is offline
Default LED's Number plate lights
Lads, another post.
I replaced the dreaded corroded boot lid handle with a brand new part. Had to order the number plate lights which i did and they worked fine except they had a very dim yellow hue off them. I went to Halfords today and picked up a pair of their off the shelf bulbs for 15 quid. Fitted them but they're flickering and not coming on.
Have I tried to short route around on this in that the direct replacement LED's aren't designed for this application?
Tried reading a few posts here but can't make sense of it....
2007 Audi A8 D3 3.2 FSI
Old 4th November 2019, 05:20 PM
DailyMike DailyMike is offline
Originally Posted by irelandbuyer View Post
Lads, another post.
Hi.
LED's are polarity-sensitive, so...with the lights switched on, try plugging the LED's in t'other way. and see if thy spark into life.
This worked on my Range Rover number plate lights (LED's) this morning to get through the MOT!
Good luck! I hope your solution is just as simple....
DailyMike.
Current modes of transport:
2004 A8 4.0DTI Quattro
19"wheels; Silver; 109,000 miles; Been off the road for several years. Lotsa work to be done
[BSold with regret:]2002 A8 4.2 (40v) Quattro Sport, 18" QS wheels; Prins LPG[/b], Silver; Black leather; newly-refurbished wheels in Anthracite...pics to follow soon!
2000 P38 Range Rover Vogue 4.6 V8 LPG, Epsom Green, fully-rebuilt engine (Top-hat liners, new camshaft for better mid-range torque); New S/S sports exhaust...SOUNDS BRILLIANT!
2014 Mondraker TrakkerR; 29-er, 30-speed gear train; rise'n'fall saddle; Mountain bike...NOT a cart-horse!
"JONDOR" a 116' long, 17"6" beam Humber Barge, Built 1950, ex oil tanker, fully refurbished Gardner 6LXC engine for propulsion (one day); requires new marine gearbox; 2-cylinder Petter Diesel engine & 3-cylinder diesel auxilliary engines with 12/24v and 230/415v gensets
"JONDOR" is a slow-burn project, being converted to provide suitable accommodation for wheelchair users and their carer/family for short respite breaks. Currently moored on River Humber at Old Beverley Shipyard
SOLD***2006 LWB Ford Transit 2.4 Diesel, Luton Van; Tail-lift; leaking translucent roof SOLD***
Previous vehicles:
Far too many to list individually, but includes 2005 A8 D3 3.0TDI Quattro Sport; 2007 A6 3.0TDI Avant; 2005 A4 2.0 Avant; 2007 A3 2.0TDI; 7-off Citroens, Many Fords, Austin 1100 (my first car), Lotus 7, Rover SD1 3500; SAAB 9000i, SAAB 9000 turbo; BMW 530; another P38 Range Rover (the crap one with BMW 2500 diesel engine...wouldn't tow the skin off a rice-pudding! )
Daren't even mention the traumatic Morris Marina and Ital's....even an Austin Princess. Brain is now hurting somewhat, so giving up for now...
Old 4th November 2019, 09:04 PM
Many LED festoons don't have a load resistor and heatsink to trick the bulb check into thinking the bulb is still there (LEDs on their own don't pull enough power). The lights are then disabled until the ignition is cycled.
You need the type with either the metal fins or the ones that look cast in ceramic (these are a better fit) I find they are a little bright so turn them round 45 degrees.
Old 5th November 2019, 11:44 AM
homer simpson's Avatar
I recently did exactly this, new boot handle and LED bulbs from ebay. Working perfectly, I'll try and find the link
Old 13th November 2019, 09:42 AM
It's weird because I had the normal bulb and an LED in and it worked OK. When I went just now to replace the other one with an LED now neither work.....gremlins...
Old 13th November 2019, 06:08 PM
Yes, that is how it was for me first time around!
Old 13th November 2019, 06:13 PM
If LEDs are a problem why not just use normal filament bulbs?
The rear numberplate is yellow after all (in the UK anyway) so LED lighting is a bit pointless. I gave up on it ages ago for that particular function.
And the OEM bulbs Audi use seem to last forever.
Old 13th November 2019, 07:46 PM
These were the ones I bought, just double check the size
https://www.ebay.co.uk/itm/AUXITO-36...EAAOSwigRdd33t
