Old 27th November 2019, 05:38 PM
Ronin Ronin is offline
Default Boot seal part codes
Hi does any of you have the part codes for the 2 boot grommets? mine have long been gone and I can't find them on www.oemepc.com as the part diagram shows it as an 'non orderable part.'
Do any other VAG parts/part number can fit those 2 holes?
Old 28th November 2019, 11:04 AM
Lots of us have had issues with these grommets perishing over time, and as you've found, you can't get them. Part of the problem is that they are moulded onto the cables somehow.
For a possible solution to your problem, check out the following thread, with the magic word being Sugru:
http://forum.a8parts.co.uk/showthrea...ighlight=sugru
Old 28th November 2019, 04:06 PM
Thanks for this, If i won't find anything else ill resort to it.
In the mean time i took a chance and bought the below, it has the same diameter hole as A8 both for the body panel and the line that goes through it. I'll try it and report back
Old 28th November 2019, 04:45 PM
Now THAT looks VERY interesting, where did you get it and what's the part reference?
Old 29th November 2019, 02:54 PM
part number is 8D0971841D I had to order it from Latvia, if it fits I'll post an update with a pic.
Old 3rd January 2020, 04:29 PM
Exclamation Update!
The above part did not fit and I returned it.
Part 4B0971841F which is a VAG part fits the hole behing rear right lamp, its a proper snug water tight fit. This grommet was found on an audi A4 from 2006. If you trace negative alternator cable up to the battery you will find it in the bulkhead:
I also found a Suzuki part to fit the rear boot lid I will post a part number, location on the donor car and pics in another post shortly.
