Old 15th February 2010, 04:35 PM
topgolfer1's Avatar
topgolfer1 topgolfer1 is offline
Default rear blind switch query
Hi,I am using a rear blind switch to operate the garage door opener as I have a spare slot in the dash,and had this set up in my old A8,and I really miss the convienience of it!!!
My question is, does anyone know which of the switch pin outlets, on the back are for illumination?
I know pins 4 and 6 are for the garage door remote.that works fine,its just it would be nice if it illuminated.
Rich
Old 15th February 2010, 09:09 PM
Flash git....
Pins 1 and 3 are illumination - Pin 1 is grey/blue (positive) and Pin 3 is brown (ground)
Just piggy back them off any of the other switches that are already there (ESP for example), you'll see the wires are the same colour throughout
Old 16th February 2010, 09:27 PM
CliveH's Avatar
CliveH CliveH is offline
That's really cool! Nice one Rich
Present: S4 B8 avant, fully loaded, MRC Stage2, Milltek non-res, KW springs
Past: S8 D2 FL, S2 ABY coupe, RS6 C5 saloon, RS4 B7 saloon, S4 B5 saloon, S4 B6 avant, all gone but not forgotten
Old 17th February 2010, 04:34 PM
topgolfer1's Avatar
Default job done
Cheers Ian for reply,spot on as usual,picked up from the vent wiring in the end,as it had those wires exposed,rather than the switches, as their wiring is wrapped in cloth.
Thanks for the thumbs up Clive
Old 27th February 2010, 04:56 PM
Good idea, I'm going to look into doing this too.
