Old 9th January 2020, 07:47 PM
irelandbuyer irelandbuyer is offline
Default Replacement top arms & Banana Arms - Any advice?
2nd Post. I've to change also the top and bottom arms. I have read through all the posts here and I'm a bit confused on what the general opinion is on the different makes.
To buy OEM I'm looking at a £1600 spend on parts before labour:
Front suspension replacement control arms:
Top £143.00 x2 (Part #4E0407505E)
Bottom £224.00 x2 (per side) (Part #4E0407693N).
Front suspension replacement banana arms
£440.00 per side. (Part #4E0407253Q)
Would anyone have any thoughts on acceptable aftermarkets?
Again, excuse my ignorance but is the labour huge on this also?
2007 Audi A8 D3 3.2 FSI
Old 9th January 2020, 07:58 PM
OE is Lemforder TRW (both the same company ZF). You can get the TRW cheapest from autodoc.co.uk. search on the VAG part number to see alternative brands.
I am about to do my bottom ones again, the ones that the damper is not attached to.
The 4E0407693 part is £64 each for TRW and have the Audi logo lasered off.
Why do you want to replace. 4E0407253Q. - I think that's a mistake.
Old 9th January 2020, 08:13 PM
Hey Snap....Thanks for such a prompt response (As usual!!!)....I really need to send you some beer vouchers....
On the 4E0407253Q, i'm just reading off the report which said "Recommend front suspension banana arms replaced on both"
Old 10th January 2020, 03:10 PM
4E0407253Q is the upright/steering knuckle. That would only normally be replaced after a crash or something. It has no wearing parts. You would only replace if damaged. I think the meant the front and/or rear lower arms - at least one of these looks like a banana, 4E0407253Q looks nothing like one.
https://audi.7zap.com/en/rdw/audi+a8.../4/407-407001/
I think they meant 4E0407151L (1) not 4E0407253Q (12)
