D4 - Axles, Brakes, Suspension and Steering Brakes, Springs, shocks, steering racks, steering columns, suspension arms, wheel hubs etc. |
Thread Tools
Display Modes
Hi all,
i replaced my front left strut in the summer with a used 4H0616039AD. in December the front right went, so i ordered another used 4H0616039AD off eBay. once fitted, i found it fell overnight, checked all joints, no leak, so leg itself at fault. the seller has sent me a replacement, but once unboxed i realised the part number was unfamiliar. 4H0616039J after looking on ETKA it appears this is a SPORTS version and isn't compatible with 1BK running gear but for 2MA running gear. the seller insists it's fine to fit, but i'm not too certain, i don't want one corner of the car stiffer/adjusting at a different rate from the others. physically, it appears to be identical. what are your thoughts??
2011 A8 Executive 3.0 TDI Quattro |
Sports will probably be stiffer. I wouldn't fit an incorrect part. I've looked on ETKA and AD is superseded with AK so would use either of these.
On a separate note, a 2011 A8 is showing a AP suffix for a 1BK vehicle?
2008 (facelift) S8 with B&O, ACC, glass sunroof, reversing camera, front and rear heated seats, ceramic brakes, homelink, electric side and rear blinds, ski load through, heated fan washer jets, remote boot closing, de-flapped manifold, fridge, umbrella holder ![]() |
That was my thought, might just ask to return both for a refund.
Just don't want to offend the seller, he's adamant it'll be fine. Problem is, it's not a two minute job to fit either.
