Old 20th February 2010, 04:07 PM
B@fink B@fink is offline
Default its just toooooooo damn big
I know full well what the answer to this is but does anyone know a way of cleaning the 8 a bit quicker.........i'm exhausted hauling buckets out to clean it
need a step ladder too, i can't reach the roof
Old 20th February 2010, 06:14 PM
Well if it's not that dirty like a dusting you should just snowfoam it down, leave it on for 5 mins then jetwash off. To reduce drying tome apply a good wax, I use Dodo supernatural V2 but you can get cheaper ones. Then dry with a watermagnet. It's amazing how theese soak up water. To clean the brake dust off easily use bilbury wheel cleaner which isn't that acidic, or P21s red if you need something stronger (still non acidic).
Old 20th February 2010, 08:44 PM
darrenjoe90's Avatar
i just cheat and go to the car wash
Audi S8 Phantom Black
Old 21st February 2010, 05:07 AM
Old 21st February 2010, 08:18 AM
only joking mike i will go out this morning in the snow and give her some tlc so she looks nice and clean
Old 21st February 2010, 09:38 AM
Ska's Avatar
Ska Ska is offline
I'd invest in a detailed clean from a profeesional (including a claying plus polishing), then you could top up the wax with Collinite 915 (cots about £23) and water just doesn't stick to the paint work after this has been applied. Subsequent cleaning jobs will be very easy and quick as most of the muck comes of with a rinse of a pressure washer.
If your using buckets fella I'd try and get access to a hose at least as these cars are truly massive.
Old 22nd February 2010, 07:26 AM
How small are you?
I can bucket wash the 8 with one 10 liter bucket of hot water and any car shampoo i have got at the time and a hose pipe to rinse off.
Old 22nd February 2010, 08:16 AM
How small are you?
Wow, things are getting personal round here.....
Old 22nd February 2010, 08:28 AM
Sorry didn't mean to be rude, I’m surprised that’s all the 8 isn’t the highest car. I didn’t think about it, you could actually be vertically challenged.
Can you reach the pedals ok?
Old 22nd February 2010, 04:16 PM
lets just say that the weather down here near the ground is nicer that it is up there
i can do everything bar a stripe down the middle, its too tall and wide..indeed toooooooooooooo damn big.
and i got through 2 buckets-o-suds just to prettify it and another couple to rinse. I couldn't get close to doing the whole thing with just 1!
