Old 7th February 2020, 09:27 PM
Audi Doody Audi Doody is offline
Default Audi A8 2.8 autobox grumble
My A8 autobox has started grumbling a little whilst in drive. It doesnt do it in neutral or in park. The box performs well so really it's more of a minor annoyance. Any ideas what it could be?
Old 14th March 2020, 02:46 PM
Ronin Ronin is offline
It's probably lack of oil and filter changes. I would drive it till the end and rebuild.
Old 16th March 2020, 08:46 PM
'tis only a 2.8 fwd though. And I have an invoice for oil change back in 2015. I might have it done again..
Old 17th March 2020, 07:47 PM
Whats the millage on it?
Old 20th March 2020, 09:22 AM
Circa 103k
Old 20th March 2020, 12:34 PM
Circa 103k
Start saving!
Old 20th March 2020, 08:37 PM
103k is very very soon for it to fail my 2.8 has 143k and its on its original gearbox, clutch and never had its oil chanaged afaik until i owned it.
Old 20th March 2020, 10:26 PM
103k is very very soon for it to fail my 2.8 has 143k and its on its original gearbox, clutch and never had its oil changed afaik until i owned it.
I think 100-150k is the sweet spot for catastrophic failure! However, there are those who are getting 200k from a gearbox. The one on my S8 went at 112k (and then again at 118k less than 3 years later and 3 months after I got it, do NOT go to Driver Transmissions in Birmingham)
I believe Audi were replacing them under warranty as early as 40k
Old 21st March 2020, 09:06 AM
I thought that the 2.8s were ok re their auto boxes?!?!
She changes ok still, doesnt seem to be any other symptoms...
Old 21st March 2020, 09:18 AM
Sadly they have all the same weak spots as all the others.
Does it grumble while moving, or while stationary as well? If moving it could be diff oil level. They are notorious for leaking out of the output flange seals, FWD versions even more so than quattro. The diff could be grumpy if it's low on oil.
If it grumbles while in drive but stationary then that could be the torque converter. Hard to tell without hearing it, and even then not easy to diagnose without taking it apart.
