Old 12th February 2020, 12:25 PM
Versace Versace is offline
Default Oxygen sensors
As my car has a lot of miles, with everything I´m replacing, I will replace the PRE-CAT Oxygen sensors as well.
Which ones to buy? Bosch?
Do I have to make some adaptations after the replacement? I´ve read about some "readiness codes"...
S8 D3 FL II.
Porsche Cayenne 958 Turbo
BMW E83 X3 3.0d M-Sport
Old 25th February 2020, 04:51 PM
IT D3 IT D3 is offline
I think the Bosch ones are OE but i'm not 100% sure on that. However they are a good quality replacement so you should be fine.
Probe Lambda Sensor BOSCH 0258007351 is the one you want.
I think fitment is quite involved so do report back on how much it costs to install them - it will help others.
Old 1st March 2020, 06:14 AM
27litres's Avatar
27litres 27litres is offline
I don't think Bosch make the plug and play ones anymore - or at least I couldn't find them.
The suggested replacement has a different plug with an adapter to modify the factory plug from what I recall.
NTK (NGK's brand in the case of O2 sensors) make a direct plug and play version that I have used without any problems on my S8 for around 5 years now.
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 1st March 2020, 07:02 AM
https://www.autodoc.co.uk/spares-sea...ord=0258007351
The Hella one looks good value.
Old 1st March 2020, 07:11 AM
The inlet manifold has to come out
Old 1st March 2020, 10:08 PM
27litres's Avatar
Sorry - I was thinking D2 O2 sensors.
Just realised this is posted in the D3 engine section...
Is BFM 4.2 an inlet manifold out job for the O2 sensors?
A bit silly, they're pretty much a service item!
Marty
Family:
Sold:
1997 Audi A4
Old 2nd March 2020, 07:26 AM
One of them is. I seem to remember the engine has to come out for the other side. Two of the many reasons I don't work on D3s
Old 2nd March 2020, 12:44 PM
Inlet manifold out for the N/S pre cat sensor (in a RH Drive car)
and the LH (Drivers) Side one isnt accessible and requires engine out
Old 6th March 2020, 06:46 AM
27litres's Avatar
Which Engineer got a promotion for that idiocy?
...If I ever buy a D3, it will have 2 more cylinders (And probably 2 x the problems!)
Marty
Family:
Sold:
1997 Audi A4
Old 10th March 2020, 07:49 AM
I should imagine once the German engineer realised his error he offered himself for sacrifice!
