Old 22nd February 2010, 06:38 AM
Oli18's Avatar
Oli18 Oli18 is offline
Default Front ABS sensor part number - which one is mine?
Hi,
I'm starting my search for a replacement OSF ABS sensor - but which part number am i looking for ? Vagcat seems to be showing a number of different ones...
Oli
Name:	ABS Sensor Part numbers.jpg
ID:	761   Click image for larger version
Name:	Front Right ABS sensor.jpg
Audi A8/S8 D2 Flickr Group
Old 22nd February 2010, 08:15 AM
I'd check with our David - Seem to recall Frank was one of the early facelifts that still had the Preface style steel hubs, so likely his ABS sensors will be the pre facelift independent ones with no built in connections for the brake pad wearing etc, but I'm not 100% - I'm pretty sure he'll remember....
Old 22nd February 2010, 05:15 PM
Oli18's Avatar
Thanks Ian - i will give Dave a shout...i think you're right though...i assume this is the old style version?...
Oli
Old 22nd February 2010, 05:24 PM
That's exactly what the one on my PF A8 looked like, not sure what the FL ones look like as thankfully not had to change them on my S8.
Old 7th March 2010, 10:08 PM
Hi,
Oli
its either the first one or the 2nd one Oli dependant on your wheel/disc size (see the detail) the last 2 are for the diesel and the LWB
Old 19th April 2010, 06:04 PM
Oli18's Avatar
I managed to get a new OEM front sensor for £55 off fleabay.
I remember Ben saying that when you put them back in, you shouldn't actually push them all the way in...
...does anyone have any guidance on this?
Oli
Old 19th April 2010, 07:48 PM
Ben does!
Not helpful I know, but ......I..............couldn't......resist.....it!
Old 20th April 2010, 08:03 AM
Oli18's Avatar
Ben does!
Go play with your buckets Conan!!
If anyone can come with a sensible answer that would be great. I just want to make sure i don't damage the sensor in any way.
Thanks,
Oli
Old 20th April 2010, 09:51 AM
I pushed mine in all the way if that helps ... The problem you've got is that if it's not far enough in it doesn't work (as it were...).
Old 20th April 2010, 01:25 PM
Oli18's Avatar
Makes sense - i think i'll push mine in bit by bit and keep testing until it works.
Cheers Psyche,
Oli
