Old 15th March 2020, 03:19 PM
RS6's Avatar
RS6 RS6 is offline
Default Headlight bulbs help anyone seen these before??
One of my sidelights has failed in my headlight, garage asked me did i fit these bulbs? whilst in for its MOT they reckon these have been retro fitted as the opening has been drilled out.
nope not me!
now I have sad orange standard bulbs back in as replacements did a quick look on ebay but can't track these down really
Does anyone know where i can find these again?
Abarth 500 Esseesse - Sold
RS6 Avant Black - Stolen
Mercedes Benz CLS 500 - Sold
Corsa VXR Nurburgring - Sold
RS6 Avant Grey - Sold
Seat Leon Cupra R - Sold
Old 15th March 2020, 03:45 PM
They look a little like the ones I fitted when I refurbished my bi-xenons (details in the thread below, including pic of bulb)
http://forum.a8parts.co.uk/showthread.php?t=9336&page=2
Amazingly the ebay link still seems to work:
https://www.ebay.co.uk/itm/H6W-BAx9s...f-e0fa81e3342e
Not identical to yours, but possibly close enough to buy a pair?
I think I included some measurements of the bulb in that thread, as the housing definitely needed opening up a little to allow them to be changed from the back of the light
Old 15th March 2020, 04:43 PM
RS6's Avatar
RS6 RS6 is offline
many thanks Adrian for your help
I will order those as a replacement
The garage mentioned when they tried to remove them they had to remove the whole head light lense and were worried about breaking the headlight does that sound like something that has to be done when fitting these bulbs maybe an access issue?
I have never really looked at the headlight in great detail
Old 15th March 2020, 05:20 PM
I got a different design that work well and didn't need any cutting/drilling. Documented somewhere but I can't easily find it.
However, if you've already got larger apertures it's much easier.
No particular problems fitting them though...……….. Maybe your garage doesn't know how to access the bulbholders?
(IIRC they just pull out, but maybe with a larger aperture that's changed?)
Old 15th March 2020, 05:35 PM
This is my 2013! post when I replaced the sidelights - still working!
http://forum.a8parts.co.uk/showpost....5&postcount=61 It will show you what my bulbs look like, though no longer on eBay of course.
And this is what they (still) look like lit. http://forum.a8parts.co.uk/showpost....9&postcount=13
Old 15th March 2020, 08:12 PM
As per the thread I made, the modification to the inner lens is needed to allow them to be drawn out from the back. It is just a light Dremel so the garage may be happy to do, based on the info in the link?
I didn't fancy having to take the lens off to change a bulb, but then being LEDs they shouldn't need doing very often!
Andrew's would be the less hassle option, if you don't mind the design
