Old 15th May 2020, 10:41 PM
Versace Versace is offline
Default AC without function
I have replaced a compressor after I bought the car as the Original one was faulty. I replaced the AC condenser and dryer as well, so those components are new. Now for the problem. The AC is not cooling the car! If i turn on/off the ECON it does not make any difference. I thought it was the water valve with the pump and I replaced it as well, but makes no difference. If I set it to warm, it does blow hot air, but in LOW setting, like it was without AC. The system is 100% leak free as we tested it couple of days ago. What could it be?
I have few codes in HVAC module but none for the Hot/Cold air flap, but I do have the code:
01087 - Basic Setting Not Performed
005 - No or Incorrect Basic Setting / Adaptation
If I do the basic setting test, it does not finish, it throws an error.
Guys what else can I do??
S8 D3 FL II.
Porsche Cayenne 958 Turbo
BMW E83 X3 3.0d M-Sport
Old 16th May 2020, 11:29 AM
homer simpson's Avatar
Silly question, was the compressor the correct one? The pressure switch (G65) would also cause the air con not to work, see if it is in the codes.
Sorry I can't help with why it errors. Do you need to login first?
Old 16th May 2020, 12:22 PM
The compressor is nissens brand new unit and it is the correct one.
No errors whatsoever for anything related with the high pressure system.
Only rear footwell heating elements and some flaps.
Compressor works as the high pressure hose gets iced up.
S8 D3 FL II.
