I finally bought both OEM cam tensioners (it's STUPID how they charge a ton on money for them!
Don't forget valve cover gaskets.
Not sure what sort of maintenance your car has had, but now would also be a great time to do the timing belt, water pump, thermostat, fan bearing, serpentine belt, serpentine belt roller/tensioner, spark plugs, etc.
-Andrew 1967 Bus 1980 Rabbit Pickup 1992 Corrado 2001 S8 2010 Jetta TDI Cup Edition |
You will also need the gaskets under the tensioners, good quality silicone sealant, and assuming you leave the exhaust cam in place one cam blanking cap and I think three cam oil seals.
Gasket: 077 198 217 (2x) Blanking cap: 078 103 113 E (1x) Cam oil seal: 026 103 085D Audi prices for the cam seals are stupid so I usually buy Elring. |
![]() Quote:
