Old 16th June 2020, 09:43 PM
Readie Readie is offline
Default Lowering springs and rear callipers/brakes
Hi all, i have just had an mot fail and need to replace a rear calliper(And disk and pads) on one side, so was thinking about what simple bolt on upgrade there is. Can I just check, the d3 w12 is a straight upgrade-correct ? I am running 19 inch wheels...
Also have rust on springs so was thinking of some slightly firmer and a tad lower...any suggestions?
Any help appreciated.
current:
- newbie to audis, 2001 s8 purchased aug 2018, changes have begun... centre box delete and straight through pipes.
- e9 csl 1972, fully restored, silly bits to finish
- 2002tii 1972, 'bought by accident' and work in progress
- toyota hiace camper, just repainted in gulf racing colours and now getting used
- honda c90 custom cub, ' bought by accident'....there seems to be a them here..!
(Not so) Recently departed:
- very sadly sold to fund the e9....BMW e28 m535 white 1986, owned 12 years, I loved that car.
- red mk1 vw golf gti, fully sorted: resprayed, flash red, mk2 1800 16v conversion, uprated brakes, shocks, leather interior,
- 1986 Saab 900 turbo convertible sold to get Audi on 'one out, one in' rule imposed by missus...not really adhering to the rule at the moment as can be seen..!
Old 16th June 2020, 10:10 PM
D3 brakes bolt on to D2 A8, but not S8 with Brembos. You'd need to swap to A8 uprights.
Old 17th June 2020, 10:24 AM
Thats true of the fronts but the OP is talking about rear brakes?
I seem to remember that there was an RS6 rear upgrade to go with the D3 S8 or W12 front brake upgrade on a D2?
Old 17th June 2020, 10:29 AM
Good point. D3 rears don't work at all on the D2. The bolt spacing is wrong, plus they have the electronic handbrake.
C5 RS6 calipers and carriers work on the rear of the D2 when using C6 S6 disks, or if you machine a small amount off the hub you can use original C5 RS6 disks too (crazy money). But, you need A8L handbrake cables which are NLA
It is possible to space the D2 calipers out to also use the C6 S6 disc, using machined adapters, but I can't find where to buy them and they are non-trivial to make by hand. Thats still D2 calipers though, with their silly postage-stamp pads.
Old 17th June 2020, 11:52 AM
Oh Joy so yet again no easy solution caused by Audi's decision to "NLA" everything that suits them
Sounds like we need to have a forum on new solutions to upgrade D2 rear brakes! its one thing Id still like to have done to mine
Old 17th June 2020, 12:14 PM
Is it just accepted that the standard S8 D2 brakes are a bit rubbish? It was one of the first things I noticed when I drove my car for the first time. Compared to my A4 of the same year which stopped on a dime.
I've replaced discs, pads, rear callipers, flex brake pipes and sorted the corrosion behind the front calliper slide plates. I've changed the brake fluid using a pressurised bleed tool but they still feel a bit lacking.
Audi S8 D2 2002 88k mls
Old 18th June 2020, 03:16 PM
Yes, they’re pretty poor IMHO. And, like3 MJ says, the rear pads (and calipers and discs) just don’t even look the part. Oh for a simple upgrade!
