Old 13th August 2020, 02:58 AM
Shel155 Shel155 is offline
Default Fault code 00862 - Antenna for GPS Navigation
I'm slowly picking away at my stored codes. Most are gone, cleaning both wheel sensors fixed my "gear recognition" code, this one remains. I do have two disconnected wires in the trunk, comming from the wiring at the rear/left. They're just laying in the rear of the trunk comming from the left side, they have spade connectors on them and run about half the width of the trunk. Can someone tell me where these are supposed to go? Thanks
00862 - Antenna for GPS Navigation (R50/R52): Open Circuit
Possible Symptoms
Navigation System not working
Possible Causes
Wiring and/or Connector(s) from/to Antenna for GPS Navigation (R50/R52) faulty
Possible Solutions
Check Wiring and/or Connector(s) from/to Antenna for GPS Navigation (R50/R52)
Check/Replace Antenna for GPS Navigation (R50/R52)
