Old 11th October 2020, 09:16 AM
carmel120 carmel120 is offline
Default front strut
hi does anyone know is there a top bearing on the front strut as there is some clicking from the top of the strut.
thanks in advance Trevor
Old 11th October 2020, 11:09 AM
homer simpson's Avatar
Is it knocking? When does it do it? Have you checked the upper control arm bushes?
Old 11th October 2020, 12:37 PM
None that I'm aware of. I just undid four bolts at the top, as can be seen in the attached image of a strut. As homer suggested, it may be the upper arms, both the bushes and if the bolts are tight.
Old 11th October 2020, 09:11 PM
cheers guys the upper arms was replaced last year with febi ones but there seems to be a jingle noise from sounds like the top of the strut .
Old 12th October 2020, 12:04 PM
"both the bushes and if the bolts are tight" that gibberish was supposed to suggest that after you check the bushes, also ensure the bolts are tight. Soon after getting the S8, I replaced the front wheel arch liners and discovered that the top two inward bolts for the arms were loose. One took a complete turn to tighten, the other literally had a 1/4 inch gap (that's how I spotted it).
