Old 22nd January 2021, 08:57 PM
S81 S81 is offline
Default Valve cover gasket replacement
I'm changing the valve cover gaskets as I want to change spark plugs,and there is oil in a couple of the plug wells ,I've got the oem gasket for drivers side and a febi one for passenger side ( oem only available cw new cover due to a warping issue on early vehicles on passenger side ) and it's several hundred for new cover and gasket so I'm going to try the febi one to see what happens ,my question is should I put a small amount of gasket sealer at the corners or not
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 23rd January 2021, 08:32 PM
S81 S81 is offline
Would anyone have the part no for the control valve seals? Also am I right in saying all 4 seals are the same
ID:	25272   Click image for larger version
ID:	25273   Click image for larger version
Daily driver
Previously owned
Old 23rd January 2021, 08:58 PM
In the attached diagram, do you mean the o-ring seal (30)? If so, the part number is WHT002789. Just over £3 from dealer.
Old 23rd January 2021, 09:06 PM
S81 S81 is offline
That's it ( i spoke to dealers earlier this week but he couldn't find the part no ) thanks sean
Daily driver
Previously owned
Old 28th January 2021, 01:55 PM
Kazs8 Kazs8 is offline
Guys can anyone confirm size of o ring that’s fits on the vvt solenoid
I came across thread online saying it’s a R11 5/8” x 3/32”
Old 28th January 2021, 02:17 PM
The only info I have is 14.8x1.9 which I'm assuming is millimetres.
Old 28th January 2021, 08:25 PM
S81 S81 is offline
I've got 4 new ones for my car ,i'll look tomorrow night and see if there's anything on the packet
Daily driver
Previously owned
Old 30th January 2021, 08:20 PM
S81 S81 is offline
I checked that today and there's nothing on the packing labels,I measured it and its approx 17 mm centre to centre ,I changed all 4 of them today and the old ones were hard and tight ,the new ones we 're slight loose i thought on the valve but when I put valves back in they were nice and tight when I seated them ,they were £3 each approx as Sean had said they are just normal o rings but i went with the genuine as i wasn't able to be sure of getting the correct size
Daily driver
Previously owned
Old 30th January 2021, 10:53 PM
Thanks for getting back, I have a leak on right side Lower left corner
Took cover off & looks like it’s wraped as does not sit flush against a straight line so have ordered a new cover & will change o ring on the solenoid
Old 5th February 2021, 06:12 PM
Do the vvt solenoids have one O ring each ? Thanks
