Old 15th December 2021, 04:01 PM
quattronutter quattronutter is offline
Default Engine sound proofing
Does the 3.0tdi usually have the thick padded sound deadening on each head as per the v8 tdi's? If so any part numbers?
Old 15th December 2021, 06:35 PM
Not saying no as I don't have any experience of those engines, but can't find anything in the parts catalogue for anything other than the plastic cover itself (059103925AF or 059103925BF), which might have some sound deadening material attached.
Old 15th December 2021, 09:12 PM
Not seen any on a 3.0,the 4.0tdi had some hefty sound proofing on engine cover and heads
Old 18th December 2021, 10:06 AM
I've had the 3.0tdi and 4.2tdi both had foam underneath the engine cover, the latter one the foam crumbled away so I stripped it off the engine cover
Old 18th December 2021, 10:45 AM
Not sure what foam would do, soundproofing to be effective needs mass as well as a degree of softness.
