Old 16th May 2022, 09:43 AM
Fredde Fredde is offline
Default Mfsw relay location
Hello i am trying to retrofit tiptoeing controls to my mfsw but can’t seem to find the relay/module that I need t change. I already have the wheel installed. Does anyone know where it is located. I have already checked the passenger footwell and ecu/tcu box.
D2 A8L 4.2 AQF 4.2 LZ9W Ebony Black Pearl Fully electric rear seats D3 s8 front brakes s8 mirror housings 18x8 Avus 3 winter wheels PDC rear blinds Nav Electric steering wheel adjustment TPMS Leather pack 1 with retrofitted stitched leather lower dash panels folding auto dimming mirrors solar sunroof cold weather package CD changer double glazing all around memory seats passenger seat adjustment from rear seat Bose servotronic xenon plus headlights
C5 Allroad 4.2 BAS 4.2 LZ6G Irish Green Metallic Bose RNS-E Rear Blinds folding auto dimming mirrors Heated MFSW with shift buttons PDC Recaros heated seats all around CD changer Nav
B5 A4 STCC Edition AJL 1.8T Quattro Built engine GT28RS maxxecu Remote locking Trip computer Sport seats Eibach/Bilstein suspension Flexfuel
D4 A8 4.2 TDI
Previous Audis B7 S4 Avant B5 A4 Avant 1.8T B8 A5 SB 3.0tdi C5 A6 1.8T C5 Allroad 2.5 TDI
Old 16th May 2022, 09:51 AM
It should live in the footwell relay box as far as I know. The wiring diagrams should be in the Tech Dump and should show the location of it.
Old 16th May 2022, 09:53 AM
Thanks MJ will check those and keep looking.
D4 A8 4.2 TDI
Old 16th May 2022, 01:02 PM
Do you mean tiptronic? +/-?
I'm sure I read somewhere (in this forum) that the wiring just parallels the +/- control on the gear selector. So is anything needed other than correct wiring?
That said, I know on my S8 that those steering wheels controls work all the time, even when in normal Drive mode, no need to move the gear selector first.
I have a late model with the PRNDS shifter, is that relevant or not? e.g. Gearbox ECU version?
Old 16th May 2022, 02:12 PM
On the standard steering wheel the tip buttons are just wired in parallel with the switches in the shifter. On the MFSW they are wired in to the module in the steering wheel which then talks to the module in the relay box, which then sends on the relevant commands to the radio or TCU, I think via canbus although not 100% on that. It might be wired in to the shifter - I'd need to check the diagrams.
Old 16th May 2022, 02:22 PM
Following on from this other thread about relays (and their location):
http://forum.a8parts.co.uk/showthread.php?t=16668
and also a LHD model, positions 3 and 4 (the two central ones) are labelled as 'Control unit for multifunction steering wheel' or ''Control unit for multifunction steering wheel for vehicles with telephone'.
Old 16th May 2022, 09:05 PM
As per steamships post, i seem to recall they live behind the drivers knee panel above the pedals.
They look like relays, but are actually control modules.
To add tiptronic MFSW to a car with MFSW, you will need to change the steering wheel (already done by the sounds of it), change the control module, and then run connections from the control module carrier to the tiptronic controls on your gear shift so the up/down control works.
I did a heated, tiptronic, MFSW retrofit to an S8 with the standard 3 spoke tiptronic wheel many, many many moons ago but for some reason the details seem reasonably fresh in my grey cells !
