Old 3rd April 2010, 07:15 PM
jeremyp's Avatar
jeremyp jeremyp is offline
Default Front Central Airvent
Can someone give me some quick pointers on how to remove the central air vent?
Actually, I need to remove the complete stereo cage - does anyone have a link to instructions?
Jeremy
2000/X Silver 2.8 D2 Sport
Old 3rd April 2010, 07:37 PM
Have a gander at this.
Old 3rd April 2010, 08:36 PM
jeremyp's Avatar
Conan
I did see that - is it the same for FL ?
Jeremy
Old 3rd April 2010, 08:48 PM
I think so. Only the centre console changed not the dash.
Old 6th April 2010, 09:03 AM
FL and PF are the same for the cage, which makes them interchangeable conveniently.....
There are 2 screws up behind the center vents holding the cage in, and 2 screws at each side, but you'll need to remove the transmission tunnel covers to get to them.
The screws all require a 4mm allen head.
The tranmission tunnel covers are held on by a single crosshead screw in the middle of the carpetted section, although these are often missing as people struggle to refit them !
The drivers one is a little tougher as you have to remove the lower dash trims and left foot rest to get access.....The lower dash trim has two 4mm allen bolts up by the steering cowel at either side (pull off the u shaped piece of trim underneath the cowel), then there are 3 more bolts, 2 logically at the bottom of the trim, and 1 hidden up in cubby hole for the service book. These other bolts are likely 8mm hex drive.
The foot rest is held down by 2 x 10mm nylon nuts and then can be a pain to get to, but a bit of patience will yeild results !
HTH.
Old 6th April 2010, 09:10 AM
jeremyp's Avatar
Thanks Ian.
You're a star.
I've had a long email conversation with Carl. I have found a double din Vavona facia and I need the cage and climate from you guys.
Ideally I need them tomorrow (next day). Am I best to call him?
Jeremy
Old 6th April 2010, 09:25 AM
Yes, speak to Carl/a8parts for all things part related.
They do have express options, but they are on catchup from a bank holiday weekend today so will be very, very busy - I recommend calling as soon as possible if you want a chance of getting it out today...
Old 6th April 2010, 10:04 AM
jeremyp's Avatar
All sorted - Carl very helpful. So conversion from FL single DIN to FL double DIN at the weekend!
Do I need to make tools to remove the vent? I'm guessing just pulling from the outside will cause damage?
Jeremy
Old 6th April 2010, 10:24 AM
In practice, levering gently with a screwdriver should work fine. The dashboard is very soft and wont mark, so take it easy and she should come out no probs...
