Old 22nd December 2022, 06:24 PM
Default Battery replacement - is there a way to do it?
I had to replace the battery again today (I had 3 Yuassa batteries under their 5-year guarantee) and, boy, is that a pain! I always end up trapping the positive cable at the side of the battery, and it won’t come out. So the battery has to come out to try again. This time, I got SWMBO to hold the positive cable aside with a thin piece of wood whilst she sat in the boo! And that finally worked!
Who on earth designed this stupid location for the battery - just another inch on the battery compartment would make it so much easier.
Or is there a way of doing this that I’m too daft to have discovered?
Old 22nd December 2022, 06:56 PM
Its a hateful process. I use a piece of string to tie the positive terminal to the boot hinge and then lean over the wing and drop the battery in at 45 degrees. Its still a pain in the arse.
Old 22nd December 2022, 07:05 PM
Mine is a serious pain in the back!
I could hardly get out of bed this morning (compounded by six pints and a couple of drams at our village Christmas party in the church last night )
Old 22nd December 2022, 07:54 PM
Nognar Nognar is offline
Bungee cord
Yuasa Silver batteries have caused me many headaches in my S8.
Now running a Varta Silver and it’s been excellent
2001 Audi A2 1.4 SE - Jaipur Red Pearl
Old 22nd December 2022, 09:39 PM
The last time I replaced the battery, Adrian (Adrian_E here I think) very kindly offered to procure and fit it for me!
Mainly so we could have a "mini-meet" at his house.
He knew how to do it easily and between us it was a quick and easy job.
I just don't recall any "tricks of the trade" he used unfortunately.
Adrian, if you spot this post, please do tell!
Old 22nd December 2022, 10:56 PM
I've always just got the supplier (either Kwikfit or Halfords...) to do this for me. Or am I missing something?
Old 23rd December 2022, 07:32 AM
I have done this several times (having had poor experience with Yuasa batteries) and tying the positive lead back and leaning over the wing seems to be the least painful way as the wing takes some of the strain out of it. I have had problems with fitting the gas escape pipe though which is fiddly.
Old 23rd December 2022, 12:42 PM
It’s been a good few years but from memory I gave up trying to fit it through the hatch and worked out the easiest way to remove the entire right boot side trim. From memory the black plastic around the lock catch has to come off first (there’s 3 plastic fixings from memory to avoid breaking), which then allows you to swivel the side trim out of the way without actually removing it from further into the boot. Gives you a nice big slot to fit the battery in then
Old 23rd December 2022, 01:47 PM
That rings a bell. Thanks Adrian.
Old 23rd December 2022, 03:58 PM
I pretty much take mine out every winter and struggle with it every time. Thought it was just me.
Audi S8 D2 2002 88k mls
