Go Back   A8 Parts Forum > A8 D4 > D4 - Engine Bay
D4 - Engine Bay Everything under the bonnet
Old 20th January 2023, 04:41 PM
Saff Saff is offline
Default Oil and filter choices
Hi,
I'm going to be changing the oil and filter in my D4 4.2 TDI soon.
I assume 507 is the required grade but was wondering what owners on here who service their own cars choose as brands. Mannol seems to be a reputable brand at reasonable cost, would this be a good choice? Also MAN, Hengst or Mahle for oil filters?
Any thoughts please? Steve.
Old 20th January 2023, 06:22 PM
I use Mannol in everything. Its competitively priced and certainly behaves well in d2 engines and gearboxes.
Hengst are an OE supplier, as I believe are MAN. Mahle I wouldn't trust as far as I can throw them these days as most of their aftermarket stuff is Chinesium with a different sticker.
Old 21st January 2023, 05:48 AM
Mannol seems OK, or OEM Quantum oil, both reasonably priced, meet specs and do the job. But I have switched to Fuchs Titan Race Pro S
Old 21st January 2023, 07:52 AM
Thanks MJ
Old 21st January 2023, 07:53 AM
Thanks ainarssems
Old 23rd January 2023, 07:46 AM
Ahem, this should have been posted by me in the D4 forum as I have a D4 but I guess the help I received from you good people should equally apply. oops!
Old 18th February 2023, 03:58 PM
Can anyone tell me if the plug from the dipstick tube can be re-used once removed. I'm going to use a Pela oil extractor via the tube. Do I need a new plug/new seals if available? Cheers Steve
2010 D4 SE Executive 4.2 TDI
Old 18th February 2023, 04:05 PM
I'm pretty sure it is just a plug, with an o-ring. Pull it out, put it back - like a dip stick without the dip-stick!
Old 18th February 2023, 04:25 PM
Yep makes sense, cheers Paul.
