Old 27th January 2023, 06:25 PM
Default D3 4.2tdi P1008/P0101
Hello I want to see if anyone else has had a similar issue/nightmare on the 4.2tdi, I've had a maf sensor fault P1008 and sometimes P0101 for over a year onto my 7th sensor so Left and right are brand new and checked for boost leaks, symptoms car looses acceleration power after about 15mins running and the engine rev to 4300rpm but with slow acceleration. Turning the ignition off and on and the acceleration is back.
I've been trying to do some logging to further investigate the issue, what I have noticed is there's a around a 50c different between left and right pre turbocharger temperatures, could this cause the issue maybe and is the sensor in the turbochargers? any help appreciated thanks.
Vcds: P1008 - Mass Air Flow Sensor 1/2
Mass Air Flow Sensor 1/2: Implausible Signal
