Hi all, I had a strange electrical surge/short the other day which created a tonne of error codes but they cleared straight away and it hasn't come back.
So, I was driving to Manchester with a friend to pickup a car for him, it's about a 2 hour drive for me it's probably the longest continuous drive I've done in the S8 since I bought it. Car drove flawless the entire way. We got about 30 seconds from our destination and suddenly the car jerked/jumped and all the dash electrics went off. Everything suddenly lit back up and I had a red "Brakes!" warning message that went away as soon as it appeared. I turned the engine off, waited a few seconds and started it again, no warning lights or nothing so we drove down the road to our destination. Whilst my friend was viewing this other car I used my carista (I have VCDS I just need to buy a new laptop) to scan the codes and it displayed the attached. I cleared the codes and almost everything has disappeared and not come back, the only stuff that has returned are the items I am aware off such as the wiper motor control and tweeter motors. Transmission: 49478 P0562 - Ultrasonic sensor right for theft alarm system (G171) ABS: 02083 - Message for Delay Request 01299 - Diagnostic Interface for Data Bus (J533) 01299 - Diagnostic Interface for Data Bus (J533) 01315 - Transmission Control Module (TCM) 01314 - Engine Control Module (ECM) Parking brake: 00456 - Control Module for Access and Start Control (J518) 00576 - Terminal 15 01315 - Transmission Control Module (TCM) 02443 - Control head 02596 - Rear brake pads worn Instrument cluster: 00668 - Supply Voltage Terminal 30 Radio: 00532 - Supply Voltage B+ 00447 - Function Limitation due to Voltage to High 00856 - Radio Antenna Sound system: 03017 - Motor for Tweeter front-left (V344) 03016 - Motor for Tweeter front-right (V345) 03000 - Amplifier for Digital Sound package (R184) TV tuner: 00447 - Function Limitation due to Voltage to High Heater & air conditioning: 00065 - Left Rear Footwell Heater (Z42) 00066 - Right Rear Footwell Heater (Z43) 00604 - Potentiometer (G113) in Positioning Motor for Air Flow Flap (V71) Auto-leveling suspension: 01400 - Suspension Level Control Central electronics: 00908 - Control Module for Wiper Motor 00908 - Control Module for Wiper Motor Body/convenience system: 01134 - Alarm Horn (H12) 01134 - Alarm Horn (H12) Driver's door: 00913 - Window Regulator Switch: Front Right (E81) Ignition authorization: 00191 - Passenger's Door Handle Touch Sensor (G416) 00955 - Key 1 Battery regulator: 02272 - Static (Quiescent) current stage 1 02273 - Static (Quiescent) current stage 2 02276 - Static (Quiescent) current stage 5 02274 - Static (Quiescent) current stage 3 02277 - Static (Quiescent) current stage 6 Roof electronics: 00211 - Control for interior lights in the back 02138 - Activation for Right Front Interior Lights 00308 - Supply voltage engines sun roof/Rolo sun roof Adaptive cruise control: 01316 - ABS Control Module 01315 - Transmission Control Module (TCM) The car drove back fine, although I did drive it without radio and the head unit was turned off. And it has not done it since. Any ideas where to start with this? |
Please post a full unedited VCDS scan. You've cut so much information it's impossible to make any suggestions.
In addition to what Matt said, can you provide the full scans of before and after. You can add the full scan using the CODE option, which will add the full scan details within a scrollable region within your post, to keep it neater. When you're replying, click on the # symbol on the second line of icons above the reply field. That will insert the text CODE surrounded by square brackets followed by /CODE surrounded by square brackets, with the cursor between them. Just paste your scan in there.
Thank you, unfortunately, that's all Carista will show me, I will get a laptop sorted so I can do a full VCDS scan.
Maybe someone local to you can help with vcds…?
2014 D4, FL 3.0tdi, phantom black, sport exec lwb 2002 D2 S8, Aqua Blue Pearl, original bar FE alloys and miltek 1997 D2 PF 4.2q, silver, Sport on roughly 90k and counting…. 1990 2.3 20v 7a Coupe Quattro **SOLD** 1996 2.6 v6 cabriolet, Isis red metallic **DEAD ![]() Had a few Audis over the years, mostly early stuff, newest was a D3 prior to my D4, nothing much kept me smitten with other marques so I floated about a bit from one thing to another until that four ring lure caught hold |
Thanks all, my repaired laptop should be arriving tomorrow afternoon, will post VCDS scan here tomorrow night/Sunday.
However the car hasn't done anything similar nor has it had any further electrical issues (aside from Auto Wipers, It looks like the gel pad needs replacing). |
As promised, see below unedited VCDS Scan
Code:
Saturday,03,June,2023,13:17:45:49881 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64 VCDS Version: 23.3.1.0 (x64) HEX-V2 CB: 0.4631.4 Data version: 20230421 DS346.2 www.Ross-Tech.com VIN: License Plate: Mileage: 95170km-59135mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E (4L0) Scan: 01 02 03 05 06 07 08 09 0E 11 31 13 15 16 17 19 1E 28 34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 65 6C 72 76 VIN: Mileage: 95170km-59135miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: OK 0000 11-Engine II -- Status: OK 0000 31-Engine other -- Status: OK 0000 13-Auto Dist. Reg -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 1E-Media Player 2 -- Status: OK 0000 28-HVAC, Rear -- Status: OK 0000 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: Malfunction 0010 38-Roof Electronics -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Malfunction 0010 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels:. 07L-910-552-BSM1.clb Part No SW: 4E0 910 552 HW: 4E0 907 552 Component: 5.2L V10/4V FSI Ŗ0060 Revision: 5AH21--- Serial number: AUX3Z0G6727503 Coding: 01060003190F0260 Shop #: WSC 63314 001 1048576 VCID: 5F9BB094FB31B162561-800A VINID: 9D196AAAA115207780086085040FEAB896 No fault code found. Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E2 910 156 C HW: 09E 927 156 B Component: AG6 09E 5,2 FSI RdW 0020 Revision: --H01--- Serial number: 0110368 Coding: 0000001 Shop #: WSC 02313 758 00200 VCID: 2411FF7892D7D2BA4B3-8070 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 D HW: 4E0 614 517 AB Component: ESP 5.7 allrad H49 0500 Coding: 0001927 Shop #: WSC 02313 000 00000 VCID: 2411FF7892D7D2BA4B3-8070 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 907 181 C Component: FBS AUDID3 H12 0200 Revision: 02005112 Serial number: AUX3Z0G6727503 Coding: 0413184 Shop #: WSC 02311 785 00200 VCID: 58E99B889E1F465A17B-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX 1 Fault Found: 00191 - Passenger's Door Handle Touch Sensor (G416) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 3 Fault Frequency: 14 Reset counter: 117 Mileage: 94256 km Time Indication: 0 Date: 2023.04.30 Time: 20:42:50 ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory BFS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063328 Shop #: WSC 02313 758 00200 VCID: 2411FF7892D7D2BA4B3-8070 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: None Part No SW: 4E0 910 769 N HW: 4E0 035 729 A Component: Interfacebox H43 1480 Revision: 00000000 Serial number: 347FQ077516035 Coding: 0000108 Shop #: WSC 11274 001 1048576 VCID: 372B38343341A922FE1-8062 Subsystem 1 - Part No: 4E0 910 611 Component: E0380 BedienteilH01 0040 Subsystem 2 - Serial number: 00000000041979 Subsystem 3 - Serial number: 0103.07.070000000100010079˙ Subsystem 4 - Serial number: 010079˙ No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 B HW: 4E0 820 043 G Component: KLIMAAUTOMAT 017 0450 Revision: 00000032 Serial number: 00000000128413 Coding: 0123601 Shop #: WSC 02311 785 00200 VCID: 1C61C798AAA7EA7AF33-8048 3 Faults Found: 00065 - Rear Left Footwell Heater (Z42) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 74 Mileage: 95145 km Time Indication: 0 Date: 2023.05.26 Time: 07:32:12 Freeze Frame: Voltage: 13.30 V 00066 - Rear Right Footwell Heater (Z43) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 46 Reset counter: 76 Mileage: 91968 km Time Indication: 0 Date: 2023.03.09 Time: 11:54:16 Freeze Frame: Voltage: 14.30 V 00604 - Potentiometer Positioning Motor for Air Flow Flap (G113) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 3 Reset counter: 94 Mileage: 93778 km Time Indication: 0 Date: 2023.04.22 Time: 07:17:02 Freeze Frame: Voltage: 14.30 V (no units): 174.0 (no units): 255.0 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.clb Part No HW: 4E0 907 279 Q Component: RLS NO RESPONSE Coding: 0133001 Shop #: WSC 02313 758 00200 VCID: 55F792BC890D7B320CD-8000 3 Faults Found: 00908 - Control Module for Wiper Motor 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 1 Fault Frequency: 254 Reset counter: 76 Mileage: 94676 km Time Indication: 0 Date: 2023.05.17 Time: 17:46:26 01520 - Rain and Light Recognition Sensor (G397) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 254 Reset counter: 76 Mileage: 94676 km Time Indication: 0 Date: 2023.05.17 Time: 17:46:26 02071 - Local Databus 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 1 Fault Frequency: 83 Reset counter: 117 Mileage: 94678 km Time Indication: 0 Date: 2023.05.17 Time: 17:49:13 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: None Part No SW: 4E0 910 121 HW: 4E0 035 121 Component: MD-Changer H42 0070 Revision: 00000001 Serial number: KE1059V7500190 Shop #: WSC 00000 000 00000 VCID: 57EB98B4930149221E1-8002 No fault code found. ------------------------------------------------------------------------------- Address 11: Engine II Labels:. 07L-910-552-BSM2.clb Part No SW: 4E0 910 552 HW: 4E0 907 552 Component: 5.2L V10/4V FSI Ŗ0060 Revision: 5AH11--- Serial number: AUX3Z0G6727503 Coding: 01060003190F0260 Shop #: WSC 63314 001 1048576 VCID: 5F9BB094FB31B162561-800A No fault code found. ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg Labels: 4E0-910-561.clb Part No SW: 4E0 910 561 F HW: 4E0 907 561 F Component: ABSTANDSREGELUNGH03 0020 Coding: 0041148 Shop #: WSC 02313 758 00200 VCID: 2517E27C99ED2BB25CD-8070 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-94.lbl Part No SW: 4E0 910 655 D HW: 4E0 959 655 H Component: Airbag 9.41 H14 4210 Revision: 91H14421 Serial number: 0037P0G0FS5D Coding: 0430707 Shop #: WSC 02313 758 00200 VCID: 270BE874E3E139A26E1-8072 Subsystem 1 - Serial number: 63328RB402B9EE23X Subsystem 2 - Serial number: 63428RB402B9F085T Subsystem 3 - Serial number: 63528RB402B9EFE24 Subsystem 4 - Serial number: 63628RB402B9F0DB% Subsystem 5 - Serial number: 63729RB402915BC5S Subsystem 6 - Serial number: 63829RB402915BF1S No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 A HW: 4E0 953 549 C Component: J0527 0410 Revision: 00H04000 Serial number: 90025071860086 Coding: 0112151 Shop #: WSC 02311 785 00200 VCID: 2615E570E4EB20AA557-8072 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 H02 0030 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 931 N HW: 4E0 920 931 N Component: KOMBIINSTR. VDO H82 0530 Revision: D05 Serial number: AUDID3G6001400 Coding: 0048913 Shop #: WSC 33268 002 1048576 VCID: 2E051D50CC1B68EAAD7-807A No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 4L0-910-468.clb Part No SW: 4L0 910 468 HW: 4E0 907 468 G Component: J533__Gateway H06 0040 Revision: 00H06000 Serial number: 0100J077138055 Coding: F5F5DFFF71260E Shop #: WSC 02313 758 00200 VCID: 6C81D7583A87DAFAC33-8038 No fault code found. ------------------------------------------------------------------------------- Address 1E: Media Player 2 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 110 B HW: 4E0 035 110 Component: MP3-Changer H46 0350 Revision: 00046004 Serial number: AUZ5ZBG2030766 Shop #: WSC 00000 000 00000 VCID: 176BD8B453818922DE1-8042 No fault code found. ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None Part No SW: 4E0 910 158 HW: 4E0 919 158 D Component: KLIMA-STG. FOND 017 0230 Revision: 00000020 Serial number: 00000000057436 Coding: 0000000 Shop #: WSC 00000 000 00000 VCID: 619FB66CCD458792605-8034 No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.clb Part No SW: 4E0 910 553 L HW: 4E0 907 553 H Component: LUFTFDR.-CDC H07 6340 Coding: 0015510 Shop #: WSC 56676 001 1048576 VCID: 2C011758FA071AFA833-8078 1 Fault Found: 01400 - Suspension Level Control 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 104 Mileage: 94882 km Time Indication: 0 Date: 2023.05.20 Time: 12:24:27 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory FS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063338 Shop #: WSC 02313 758 00200 VCID: 2411FF7892D7D2BA4B3-8070 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 K HW: 4E0 919 887 B Component: MNS JP H04 0590 Revision: 0000005S Serial number: AUZBZ7G0105064 Shop #: WSC 02313 758 00200 VCID: 36353530344B502AE57-8062 Subsystem 1 - Part No: 4E1 910 336 Component: Interface Handy H08 0050 1 Fault Found: 02288 - Control Module for Chip Card Reader (J676) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 43 Mileage: 94503 km Time Indication: 0 Date: 2023.05.06 Time: 15:28:58 ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H05 0090 Serial number: 00000718400012 Coding: 0036006 Shop #: WSC 64595 001 1048576 VCID: 1D67CA9CB1BDE37204D-8048 1 Fault Found: 00211 - Control Circuit for Rear Illumination Lights 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 0 Fault Frequency: 15 Reset counter: 76 Mileage: 94392 km Time Indication: 0 Date: 2022.04.30 Time: 22:50:00 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 802 D Component: Türsteuer.FS BRM005 0180 Coding: 0032750 Shop #: WSC 02313 785 00200 VCID: 2019F36886CFCE9A2FB-8074 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4E0-910-289.lbl Part No SW: 4E0 910 289 D HW: 4E0 907 289 D Component: Komfortgeraet H08 0020 Revision: 00200008 Serial number: W040707310094 Coding: 0004840 Shop #: WSC 02313 758 00200 VCID: 2A0D1140F0F304CA71F-807E Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel P27H08 0090 3 Faults Found: 01134 - Alarm Horn (H12) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 77 Mileage: 90046 km Time Indication: 0 Date: 2022.01.15 Time: 10:30:14 01134 - Alarm Horn (H12) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 77 Mileage: 90046 km Time Indication: 0 Date: 2022.01.15 Time: 10:30:14 02107 - Trunk or Luggage Compartment Opening Motor (V254) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 105 Mileage: 95051 km Time Indication: 0 Date: 2023.05.21 Time: 10:55:58 ------------------------------------------------------------------------------- Address 47: Sound System Labels: None Part No SW: 4E0 910 466 B HW: 4E0 035 466 Component: BO_D3 H06 0180 Revision: 20S00002 Serial number: 01903070008472 Coding: 0000017 Shop #: WSC 02313 758 00200 VCID: 2517E27C99ED2BB25CD-8070 Subsystem 1 - Part No: 4L0 910 465 A Component: BO_D3_SLAVE H41 0780 Subsystem 2 - Serial number: 01304120020030 Subsystem 3 - Serial number: 0213.04.120000000100010030˙ Subsystem 4 - Serial number: 010030˙ 3 Faults Found: 03017 - Motor for Left Front Treble Speaker (V344) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 254 Reset counter: 77 Mileage: 91968 km Time Indication: 0 Date: 2023.03.09 Time: 11:55:27 Freeze Frame: Voltage: 12.70 V Temperature: 16.0°C Bin. Bits: 00000100 Voltage: 12.50 V Temperature: 20.0°C 03016 - Motor for Front Right Treble Speaker (V345) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 254 Reset counter: 77 Mileage: 91968 km Time Indication: 0 Date: 2023.03.09 Time: 11:55:27 Freeze Frame: Voltage: 12.70 V Temperature: 15.0°C Bin. Bits: 00000100 Voltage: 12.50 V Temperature: 20.0°C 03000 - Amplifier for Digital Sound Package (R184) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 254 Reset counter: 77 Mileage: 91968 km Time Indication: 0 Date: 2023.03.09 Time: 12:24:22 Freeze Frame: Voltage: 11.90 V Temperature: 16.0°C Bin. Bits: 00000100 Voltage: 11.50 V Temperature: 30.0°C Bin. Bits: 00000010 Bin. Bits: 00000000 ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 B Component: ILM Beifahrer H11 0070 Revision: Serial number: 00000000008261 Coding: 0010101 Shop #: WSC 02313 758 00200 VCID: 1E65CD90BCBBF86A1D7-804A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 801 D Component: Türsteuer.BF BRM005 0180 Coding: 0032750 Shop #: WSC 02313 785 00200 VCID: 2019F36886CFCE9A2FB-8074 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 D HW: 4E0 907 801 B Component: EPB A4EC0230 H03 0230 Revision: --H03--- Coding: 0000733 Shop #: WSC 09308 002 1048576 VCID: 2019F36886CFCE9A2FB-8074 3 Faults Found: 01487 - System Function Test 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 4 Fault Frequency: 1 Reset counter: 81 Mileage: 94392 km Time Indication: 0 Date: 2023.04.30 Time: 22:50:23 Freeze Frame: Voltage: 11.90 V Count: 32 02443 - Control Head 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00111100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 81 Mileage: 94392 km Time Indication: 0 Date: 2023.04.30 Time: 22:50:23 Freeze Frame: Voltage: 11.90 V Count: 40 02596 - Rear Brake Pads Worn 008 - Implausible Signal Freeze Frame: Fault Status: 01111000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 41 Mileage: 94064 km Time Indication: 0 Date: 2023.04.30 Time: 17:44:23 Freeze Frame: Voltage: 11.59 V Count: 61 ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl Part No SW: 4F0 910 357 F HW: 4F0 907 357 F Component: AFS 1 H01 0020 Revision: 00000001 Serial number: Coding: 0000018 Shop #: WSC 02313 785 00200 VCID: 290FEE4CF5F50FD2785-807C Subsystem 1 - Part No: 4F0 941 329 D Component: AFS-Modul links H01 0010 Subsystem 2 - Part No: 4F0 941 329 D Component: AFS-Modul rechtsH01 0010 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 N HW: 4E0 035 541 R Component: TUNER Japan H42 0180 Revision: 00000000 Serial number: 325GN077535052 Coding: 0000003 Shop #: WSC 02313 758 00200 VCID: 2B031444FF091DC28A9-807E 1 Fault Found: 00856 - Radio Antenna 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 19 Reset counter: 108 Mileage: 91968 km Time Indication: 0 Date: 2023.03.10 Time: 13:25:35 ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: 4E0-910-146.clb Part No SW: 4E0 910 146 F HW: 4E0 919 146 C Component: TV analog TUNER H15 0290 Revision: 00000076 Serial number: 00000000015579 Coding: 0000016 Shop #: WSC 02313 785 00200 VCID: 2411FF7892D7D2BA4B3-8070 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0550 Revision: 00000000 Serial number: 00000000010459 Shop #: WSC 63314 001 1048576 VCID: 2019F36886CFCE9A2FB-8074 Subsystem 1 - Part No: 4E0 915 105 A Component: von VA0 341126Q0W1 Coding: 344530393135313035412056413033343131323651305731 Shop #: WSC 65372 001 1048576 1 Fault Found: 02256 - Quiescent Current 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00110001 Fault Priority: 7 Fault Frequency: 4 Reset counter: 101 Mileage: 94700 km Time Indication: 0 Date: 2023.05.18 Time: 05:10:15 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 D Component: Türsteuer.HL BRM005 0180 Coding: 0032750 Shop #: WSC 02313 785 00200 VCID: 1E65CD90BCBBF86A1D7-804A No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 4E0-910-273.lbl Part No SW: 4E0 910 273 A HW: 4F0 907 273 A Component: Reifendruck 3 H05 Revision: 00050340 Serial number: 00000600058977 Coding: 0222428 Shop #: WSC 11918 001 1048576 VCID: 2019F36886CFCE9A2FB-8074 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 4E0-910-441.clb Part No SW: 4E0 910 441 HW: 4L0 907 441 A Component: J772__Rearview 0050 Revision: --H12--- Serial number: 525PA8-J77109R Coding: 1121402 Shop #: WSC 02313 758 00200 VCID: 5CE18798EA27AA7A333-8008 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 D Component: Türsteuer.HR BRM005 0180 Coding: 0032750 Shop #: WSC 02313 785 00200 VCID: 1E65CD90BCBBF86A1D7-804A No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 C HW: 4E0 919 283 C Component: Parkhilfe 8-Kan H12 0040 Revision: 00H12000 Serial number: 08730720812861 Coding: 0221008 Shop #: WSC 02313 758 00200 VCID: 2313FC6497D9D582329-8076 No fault code found. End----(Elapsed Time: 02:25, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
Toby Current: 2007 S8 D3 5.2 V10 - Jap Import in Daytona Grey 2004 BMW X3 2.5i Manual (Old Workhorse) Previous: 2009 S5 4.2 V8 - Phantom Black with Red leather interior 2006 A4 3.0tdi Manual - Black with Black Leather 2001 BMW 323ci 2.5i Manual |
Was enjoying a long overdue drive with other A8/S8 owners on Saturday at our 2023 (rescheduled 2020) annual meet, so missed this.
Address 05: 00191 - Typical issue with the door handles as they fail over time. I've seen it mentioned elsewhere to just disconnect the cable going to the door handle for the sensor, but never tried it. Address 08: 00065 & 00066 - Another typical issue that affects older cars. The footwell heaters basically consist of a large heatsink with four transistors bolted to them. All held in with some sort of epoxy, so you can't get at them without destroying them. Most people just live without them. Address 08: 00604 - One of the flap motors has an intermittent fault. Since you now have VCDS, you can go into Address 08 and run tests on them. It's been a while, but I think you can run Basic Settings for individual motors, and the issue might be that the motor is failing or that it is out of the allowable range. Worth checking and running that before replacing. The following PDF has instructions of how to replace. Just search for G113: http://forum.a8parts.co.uk/attachmen...3&d=1420367102 Address 09: 00908, 01520 & 02071 - Did some Googling on this and came across the following thread. Problem was with a Q7, but the same error codes as yours. Some more details can be found in SSP287. It's worth going through the entire thread to check things with VCDS, but their solution was replacing the J519 module (which has component protection), possibly caused by the car being jump started: https://mhhauto.com/Thread-HELP-Plea...326#pid1057326 Address 34: 01400 - Could be a bad level sensor or a faulty connection to it. It might even be detached. Check them first and then use VCDS to check the measuring blocks. Change the settings in the MMI and see if VCDS shows corresponding/matching changes. Address 37: 02288 - Weirdly, the VCDS Wiki doesn't even give details for this error code. Some searching did find the following thread, with the only common feature being that is was a Japanese import, although their issue was with coding the radio to work in Ireland: https://forums.ross-tech.com/index.php?threads/19743/ Address 38: 00211 - Another one that shows nothing in the VCDS Wiki, with the only 00211 being a coding reference. From the description, maybe just a faulty connection in one of the rear roof lights or switches. Address 46: 01134 - Yet another common faults with most VAG vehicles. The battery inside the alarm horn deteriorates and causes a short on the PCB, or destroys it completely. Address 46: 02107 - The motor may just be stuck. Those with the plastic casing tended to be less up to the job and would sometimes struggle. One solution would be to try dismantling and applying violin rosin on the clutch wheel. The newer ones with a metal casing are better as they have a stronger motor. This has taken longer to respond to than I expected, so I'll continue tomorrow. One comment about the scan. You don't mention if any of these error codes are showing any visible signs like warning lights on dash or items not working e.g. for 'Address 09: 00908, 01520 & 02071' do the wipers work?
Thank you for the detailed reply Steamship!
There are absolutely no warning lights on the dash, the wipers are intermittent, if I unplug the connection to the wiper motor and plug it back in, they work fine until it rains. Same for the footwell heaters, seems strange as they appear to work fine. The radio/nav errors I am fine with as it's a Jap car it doesn't work anyway, I use a bluetooth/radio transceiver to listen to music, I'm currently looking at alternative options. My main worry was the battery issue I had after a long drive, It hasn't replicated itself at all, but the furthest I have driven was Leeds since then. Overall I still love the car, I have valve cover gaskets and plugs arriving this weekend, I'll tackle that job as I can tell the original is very brittle and oil is leaking into the spark plug wells from the gasket.
Sorry for the delay, but helping other family members with jobs the last few days.
Address 47: 03017 & 03016 - Do the tweeters work, and/or are they permanently up/down in the dash? If they don't move, either the motors have failed on both of them or someone disconnected them to stop they raising/lowering. Address 47: 03000 - Would check the physical connections to the amplifier. Does the amp work? Maybe this issue is the cause of the tweeter codes. Address 53: 01487 - Try clearing all three codes and then running the following test: http://wiki.ross-tech.com/wiki/index..._Function_Test Address 53: 02443 - Two possible causes that I've come across. One is the EPB button is faulty, or has dirty contacts inside, the second being possible dodgy connections on the EPB module itself. Worth removing them and checking for signs of corrosion. Address 53: 02596 - Two possible cases, the first being the obvious ones that the pads are worn. The second is that the pad thickness adaptation wasn't done properly the last time, in which case, you could try doing that. See the following link regarding Adaptation: http://wiki.ross-tech.com/wiki/index...#Pad_Thickness Address 56: 00856 - Might possible be due to corrosion at the base of the shark fin antenna on the roof. Address 61: 02256 - This basically means that something isn't going to sleep properly. The big issue is figuring what. From the other codes, I'd hazard a guess that it's been caused by the door handle. Following on from your last response, I can only assume that the wiper motor has a faulty connection somewhere, as they reset themselves when you disconnect them. Do they stop working when it starts raining? Very odd.
