Old 6th October 2023, 07:59 AM
Mossyboy1978 Mossyboy1978 is offline
Default Selling 2002 FL S8
Morning all
I think I've come to the end of the road with my S8. It's been about 7 years and I've loved her to bits but I can't really afford to keep her on the road any longer and I'm hoping someone else can.
2002 in Aqua Pearl (rare metallic blue/purple)
Black leather with dark wood inlay
Factory bootlid spoiler
136k miles
Part service history (last service was Feb last year)
MOT until end Feb
Good bits:
Original Milltek backbox - these are super rare now
Recent custom build stainless steel exhaust with 200 cell sports cats from from down pipe to back box
20" OEM wheels recently refurbished in storm grey, with painted black calipers and S8 decals on them. Looks fantastic.
Original Sat Nav in place
Black leather has held up well - really lovely feel. Back seats have hardly been sat in
New window motor installed on driver's side
F125 switch done 5 years ago (but may need replacing again - couple of fault codes earlier this year make me think its a possible weak spot still)
Bad bits
Front bumper needs a respray as laquer is peeling
Cam belt service due but car has done less than 2000 miles since the last one
Coolant level warning light keeps coming on - coolant levels are fine and she runs at a rock solid 90 degrees all day everyday. Its a wiring issue to the instrument binnacle which needs an auto electrician to sort.
Headlight level sensor needs replacement
It drives phenomenally well - pulls brilliantly and runs like a dream mechanically. The new exhaust makes it sound unreal and releases as much power as is available from 4.2 40v.
But I can't afford to spend the money on the bad bits above - so its time to move her on.
Will be heading on to Pistonheads next week for £4k but for a genuine forum member it's available for £3.5k.
Hope someone can enjoy her as much as I have.
Sad times....
ID:	29989   Click image for larger version
ID:	29990   Click image for larger version
ID:	29991   Click image for larger version
ID:	29992   Click image for larger version
ID:	29993   Click image for larger version
ID:	29994   Click image for larger version
ID:	29995   Click image for larger version
ID:	29996   Click image for larger version
ID:	29997   Click image for larger version
ID:	29999   Click image for larger version
2002 S8 Aqua Pearl, entirely original apart from FE 20" OEM wheels and Milltek exhaust.
Old 6th October 2023, 08:26 AM
Ronin Ronin is offline
Are the rubber floor mats genuine audi ones? they are ultra rare.
Old 6th October 2023, 08:33 AM
Yes they are. I had no idea! The driver's side one has a hole in it.
Old 6th October 2023, 09:04 AM
Just to add that I thought I recognised this car when it arrived on my driveway yesterday and I was told it's previous owner was Professor Peach on here. He hasn't posted in at least 5 years though.
If Richard is happy I can post the codes from the VCDS scans (second one after a cleardown and run around the block).
Old 6th October 2023, 09:10 AM
No problem with that Andrew.
Old 6th October 2023, 09:59 AM
So the final scan (clean sections omitted) was:
Thursday,05,October,2023,11:54:15:38881
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.3.1.0 (x64)
Data version: 20230421 DS346.2
www.Ross-Tech.com
Scan: 01 02 03 08 15 17 35 37 45 55 56 76
VIN: WAUZZZ4D63N001043
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4D0 907 389 E
Component: ABS/ESP allrad D57
Coding: 08397
Shop #: WSC 02313
VCID: 316F2301FBBEBB1B74-5178
1 Fault Found:
01119 - Gear Recognition Signal
35-10 - - - Intermittent
Address 35: Centr. Locks Labels:. 8D0-862-257.clb
Part No: 8L0 862 257 P
Component: CV-Pump, Alarm, RC D17
Coding: 16235
Shop #: WSC 02314
VCID: 428D7CCD4E1830839D-4F02
1 Fault Found:
01134 - Alarm Horn (H12)
49-00 - No Communications
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00001
Shop #: WSC 00000
VCID: 0401BAD5148CFEB3EF-4B4A
1 Fault Found:
00776 - Level Control System Sensor; Left Front (G78)
28-10 - Short to Plus - Intermittent
End-------------------------(Elapsed Time: 02:14)--------------------------
And the first scan had the following additional errors:
Address 01: Engine Labels: 4D0-907-560-AVP.lbl
Part No: 4D0 907 559 AA
Component: 4.2L V8/5V G 0002
Coding: 10753
Shop #: WSC 02629
VCID: 6DD7FF7127061FFB10-5178
WAUZZZ4D63N001043 AUZ7Z0A2019960
6 Faults Found:
16804 - Catalyst System; Bank 1
P0420 - 35-00 - Efficiency Below Threshold
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
16814 - Catalyst System; Bank 2
P0430 - 35-00 - Efficiency Below Threshold
17819 - Secondary Air Injection System; Bank 2
P1411 - 35-10 - Insufficient Flow - Intermittent
17831 - Secondary Air Injection System; Bank 1
P1423 - 35-10 - Insufficient Flow - Intermittent
17521 - Oxygen (Lambda) Sensor; B1 S1
P1113 - 35-10 - Internal Resistance too High - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4D0 927 156 EC
Component: AG5 01L 4.2l5V RdW 1010
Coding: 00111
Shop #: WSC 02314
VCID: 6ED5F87D2A00E4E329-5178
3 Faults Found:
17090 - Transmission Range Sensor (F125)
P0706 - 35-10 - Implausible Signal - Intermittent
17147 - Shift Solenoid 3 (N90)
P0763 - 35-10 - Circuit Failure - Intermittent
17142 - Shift Solenoid 2 (N89)
P0758 - 35-10 - Circuit Failure - Intermittent
Coding: 08397
Shop #: WSC 02313
2 Faults Found:
01203 - Electrical Connection between ABS and Instrument Cluster
31-10 - Open or Short to Ground - Intermittent
Address 08: Auto HVAC Labels: 4D0-820-043-MYX.lbl
Part No: 4D0 820 043 Q
Component: A8-Klimavollautomat D13
Coding: 00081
Shop #: WSC 02314
VCID: 2A5D346DD668C8C3B5-2592
1 Fault Found:
00734 - Potentiometer in Central Vent (G142)
30-10 - Open or Short to Plus - Intermittent
Coding: 16235
Shop #: WSC 02314
9 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
76-00 - Terminal 30 missing
77-00 - Internal Supply Voltage
Address 37: Navigation Labels: 4B0-035-192-RNSD-37.lbl
Part No: 4D0 035 192 M
Component: RNS 4.2 H06 BNO 0102
VCID: 295FCB61D36EC3DBBC-4B18
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
44-00 - Short Circuit
Address 45: Inter. Monitor Labels: 4B0-951-178.lbl
Part No: 4D0 951 177 B
Component: Innenraumueberw. D06
Coding: 00001
Shop #: WSC 00000
VCID: 2859CE65C864FAD3A3-5178
1 Fault Found:
01462 - Anti-theft alarm ultra sonic Sensor (G209)
53-10 - Supply Voltage Too Low - Intermittent
Coding: 00001
Shop #: WSC 00000
2 Faults Found:
00774 - Level Control System Sensor; Rear Left (G76)
28-00 - Short to Plus
The central vent potentiometer issue I've had myself and fixed by moving the dial back and forth a few times. I did that to this one too.
Old 6th October 2023, 11:27 AM
Let me know if you want to sell the rubber floor mats separately, I would buy the car just for them but have exhausted all my parking space with a car for my gf
Old 6th October 2023, 12:35 PM
You can certainly have the floor mats for £3.5k
Old 6th October 2023, 01:17 PM
Does that mean someone else can have the rest of the car for free?
Old 6th October 2023, 04:04 PM
Absolutely!
