Go Back   A8 Parts Forum > A8 D4 > D4 - Fuel and Exhausts
D4 - Fuel and Exhausts Everything to do with getting fuel into the engine, and fumes back out again
Old 28th June 2024, 12:20 PM
Horrgakx Horrgakx is offline
Default Blank plugs for the exhaust flaps?
I need to get a couple of blanking plugs for the connector which usually plugs into the actuator controlling the butterfly valve in the exhausts.
There are some available in the UK but seemingly for other models - are they a universal fit does anyone know?
A8L W12 (D4 2015)
Old 29th June 2024, 09:21 AM
Not an exact answer to your question, but this may help. The actuator used in the D4 A8 is also used in the following cars (over a period of different years), and has a 3-pin connector. I'm assuming these 'blanking' plugs have some sort of electronics in them so they don't throw an error code, so one specified for any of these models should in theory work. Have you tried asking the seller if they work for the A8, or if you could return them if they don't? If they do work, it also means the seller has more opportunities to sell them.
A3, A6, A7, A8, Q2, Q3, Q5, TT, RS6, RS7, RSQ3
