Go Back   A8 Parts Forum > A8 D4 > D4 - Interior Electrics
D4 - Interior Electrics Airbags, Sensors, climate modules, instrument clusters, switches etc
Old 2nd July 2024, 04:20 PM
Horrgakx Horrgakx is offline
Default Info about a possible installed tracker
My car was advertised as "Tracker fitted" but there's no information relating to a tracker. I expect it'll be hard to find (that's the point) - but do you think it could be 'tracked' down?
A8L W12 (D4 2015)
Old 2nd July 2024, 04:29 PM
Not sure about locations on the D4, but I had two installed on the D3 I had by previous owners. One was up behind the glovebox, as there's usually plenty of room and the other was in the boot behind the side panelling, with the antenna wire up under the rear parcel shelf panelling... and unless you use the car often enough, they soon drain the battery.
