Go Back   A8 Parts Forum > A8 D4 > D4 - Sat Nav, ICE, Audio & TV
D4 - Sat Nav, ICE, Audio & TV All in car entertainment discussions including MMI 3G Plus
Old 9th October 2024, 06:25 AM
Horrgakx Horrgakx is offline
Default Air suspension won't lift
The option to raise the suspension is greyed out. I suspect it could be to do with a Software version mis-match which is flagged up on the diags machine.
I did update the MMI with a flash from TheNavMan, but their website doesn't seem to be working so I can't contact them to ask.
Any other ideas to troubleshoot please?
A8L W12 (D4 2015)
Old 1st November 2024, 04:10 PM
Butters Butters is offline
Does the Suspension Wheel Change Mode = ON show in the MMI Service Menu?
If so, and you have not turned it on, it means the air suspension is deactivated due to a fault but you usually also get a yellow warning and message, as you have not mentioned that, maybe it is a software issue?
Old 1st November 2024, 05:48 PM
Would this be why you're looking for someone with VCDS?
Since you don't have it, I'll ignore my first question to you. However, I have others:
1. Does the air suspension work in the other settings?
2. Are you getting any error lights on dash?
3. Are any corners sagging if left overnight or a few days?
Old 2nd November 2024, 07:46 AM
Thanks for your replies.
I'm not sure what that is, VCDS menu?
I don't believe there's a corner sagging and there are no warning lights on the dash.
It seems to be intermittent, sometimes the RAISE is greyed out and sometimes it isn't.
Are there certain conditions where it doesn't allow you to raise the suspension?
A8L W12 (D4 2015)
Old 3rd November 2024, 05:41 PM
The 'jack mode' is within the MMI, probably under Car. I believe when you set it, it locks the suspension so they stay at the same height after it's jacked up. That way it doesn't get confused with different sensor heights.
It's available at speeds up to 50mph and will lower above speeds of 62mph. It might be one the level sensors playing up, but you'll need access to VCDS or something similar.
Old 3rd November 2024, 06:31 PM
Ok thanks, I've not used the jack mode yet yet but will be soon as I need a couple of PZero's.
A8L W12 (D4 2015)
