Old 2nd June 2025, 06:20 PM
B@fink B@fink is offline
Default What adaptor is needed? Aerial kaput!
My aerial has gone to silicon heaven. Obviously new ones are unobtanium but a “generic” powered option can be squeezed in and a quick check works all dandy. BUT! What is the aerial connection fasten to the power aerial? It’s not a standard DIN plug and appears to be a screw in fitment. What do I need to connect a DIN cable into this unusual fitment? Anyone know?
PF late '97 D2 2.8 Aluminium Silver. Solar roof, Full Heated Leather, Double Glazing, 17" wheels, Sports Steering Wheel, Cruise, Blinds, Bose sound.
Fiat Tipo diseasel econobox with all the buttons and none of the soul that now does all the heavy lifting.
Ford Capri Laser: noisy, slow, thirsty, bouncy, no buttons but it always sounds like it’s REALLY trying and I can’t help but chuckle when it parps and boings along. And people of a certain age stare at it with a wistful look in their eyes that clearly says…I had one of them. And I sold it because of the kids
Old 3rd June 2025, 11:16 AM
Are you thinking of putting the aerial in the boot lid unit?
If so you're right, not a typical GPS aerial connector.
The thread is probably on here somewhere but ages ago I replaced the aerial on my old (long gone) PF S8 and didn't even try to get anything inside the old failed unit.
My solution was an external puck mounted at the very base of the rear screen. Worked fine.
As for connecting it I looked at various options but in the end ran the thin cable along the boot gutter (behind the rubber seal IIRC) then up the boot strut (with other cables) and patched it behind the boot lid trim.
That DID involve cutting into and reterminating the coax aerial cable. I "think" (it was long ago) I split the cable and fitted a M/F pair of "modern" copnnectors so that I could reinstate if necessary.
