Old 15th May 2010, 03:19 PM
Default Speeding up Auto Scan
Currently when running an Auto-Scan VCDS will try to scan every module that your 8 may have. To speed things up you can edit the AUTOSCAN.TXT file by clicking the link in the window below.
You can then add a line that lists only the modules that your car has thereby speeding up the Autoscan.
You can see my line added in at the top of the list below.
ID:	1101   Click image for larger version
