Old 25th June 2010, 09:05 AM
Default Changing the "oh ****!" handles
The rear seats roof handles that you normally grab when car hits a bump are scratched by previous owner. I don't know what you have to do with them to get them scratched (sharp fingernails?), but this is reality.
I need to change those handles, but ELSA suggests it's not just a couple of screws, but it also welded to the chasis, so I'll need soldering iron experience for this kind of operation.
If anyone did change those handles please advice. Thanks!
Old 25th June 2010, 12:01 PM
Zip's Avatar
Zip Zip is offline
Wink
suspect it some rep idiot who likes hanging his laundered and pressed jermyn street stripey shirts from metal coat hangers in the back of the car thats scratched them....
Zip
Old 25th June 2010, 12:53 PM
Er, its just a couple of screws - nothing more ?
Facelift they are Torx, and prefacelift they were crossheads IIRC.
Use a small flatblade to pop off the plastic cover that you reveal when you pull the handle down, and you will see the two bolts. Remove them, thats it
Concur its likely shirt hangars - Even though the 8's have a dedicated hangar, its only good for one shirt really, you need to use the grab handle for a full week away on the road
Old 25th June 2010, 09:27 PM
Thanks for your replies guys.
Removed the handles. 10 minutes job. Used plastic stick to carefully pry off plastic covers. One torx screw under each cover.
Looks like a mistake in ELSA.
