Closed Thread
Old 21st January 2009, 06:18 PM
Default Axles, Suspension, Brakes and Steering Sticky
Here we will post links to Axles, Suspension and Steering related solutions. This post will be edited by an Administrator when a new solution is found either within this forum or elsewhere on the Interweb.
PARKING BRAKE
Parking Brake Fault - From one of our very first contributors, A8Doc .
AIR SUSPENSION
Air Suspension Lowering Tip - Architex_mA8tey
How to remove and install a D3 Air Suspension Compressor
- GlynC
Adaptive Air Suspension - Full Audi Guide PDF - Richardracer
Modified VCDS labels for D3 suspension - Delboy
suspension gone harsh since battery disconnect - mechanico lee
Power Steering Hose Failure & Fix - D3 S8 - Delboy
DIY - Replacing Headlight Level Sensor - Leorio
WHEEL BEARING
Video - How to Replace a D3 Rear Wheel Hub Bearing - Youtube
BRAKES
Disk and Pad options - MatthewH
Rear Brake Caliper System Rebuild - MatthewH
Remember, if you find a solution to a problem you've had or others have posted on the web let an Admin know (PM or email) and we will add it to this sticky.
File Type: pdf Adaptive Air Suspension D3 A8 - Audi Document PDF.pdf (2.15 MB, 2291 views)
Closed Thread
