Old 4th August 2010, 08:33 AM
a8_
Guest
Posts: n/a
Default Cruise Control
I have a problem with the cruise control being intermittent. My question is wether it is likely to be the vaccum system or the stalk. The symptoms are that it either works or doesn't, and turning the car off and on can change this, but sometimes while it is on for any number of minutes it will suddenly cut out and not come back on again until the engine is turned off and on again but this doesn't alwaye cure it.
Old 4th August 2010, 09:00 AM
If it were the vacuum system, I'd expect it never to work as once the seal is gone it wont reseal.
If it were the stalk, I cant see how turning the engine on/off can help.
There is a controller for the cruise system on prefacelift which may have got some damp or something, which might reset itself a little if the power is cut / reapplied ?
Thats probably where i'd start....
Old 6th August 2010, 01:41 PM
a8_
Guest
Posts: n/a
OK thanks for the pointer. You can guess my next question is where abouts does this controller live?
Old 8th August 2010, 08:18 PM
B@fink B@fink is offline
can someone answer him please, i, ahem, might want to know too
Mine works when it likes at the mo, so i know its not the piping..........
Old 8th August 2010, 08:24 PM
From memory, it sits in the plenum chamber under the bonnet - Its the big box on the right hand side that houses the gearbox, ABS and engine ECU. Pretty sure the cruise control lives in there too, its the smallest item, slightly smaller than a pack of fags I guess, silver, 1 multiway connector on it.
Damp in there could affect the components / contacts I guess.. Check it out, and if its totally duff, I'm sure a8parts will have spares
