Old 10th August 2010, 09:30 PM
Default Brake Switch
Every time I push the brake pedal one front sidelight comes on, when I turn the lights on the rear brake lights come on and the ABS and ESP is disabled.
Also when I push the brakes the car beeps to tell me a light bulb is out. Imagine how annoying that is, a beep every time I brake.
Anyone else had this? Vag Com has brought up the brake switch as an issue, which is what Ben said it would be of the top of his head. How can I find the brake switch and where can I get one from tomorrow morning? This is driving me nuts...!
Old 11th August 2010, 06:22 AM
Mkoneman's Avatar
Mkoneman Mkoneman is offline
sounds more like you have the wrong bulb in the brakelight, id replace both brakelight bulbs 1st
www.facebook.com/obdworks
full genuine ross-tech vcds
full genuine vag- tacho
Old 11th August 2010, 07:19 AM
I'd concur... theres something wierd going on here - Have you swopped over the USA lenses? Did the problems start after that by any chance ?
