Old 23rd October 2010, 01:12 PM
spinedoc
Guest
Posts: n/a
Default D3 wheels on a D2 possible?
I'm liking some of the stock D3 wheels, especially the larger 18-20" ones. Is it possible to use a D3 wheel on a D2 (1998 A8) ?
Old 23rd October 2010, 02:32 PM
perfectly possible spinedoc you just need to ensure that the rolling radius's are same front and back (or within 1%) or the quattro will be confused. 19 or 20" by 8.5 or 9" wheels are perfectly possible all around.
Old 24th October 2010, 01:28 PM
spinedoc
Guest
Posts: n/a
Sweet, I plan on just using the same tire size front and back (not staggered) so that shouldn't be an issue. Some of the other forums are telling me the max is a 19" and/or 8.5 width though.
Old 24th October 2010, 01:53 PM
Well mine are 9x21 front with 275 35 21's and 10.5 x 21 at rear with 295 25 21's. Singh has 20 x 9 with 285 35 20 all around on his I think!!!
Old 24th October 2010, 03:47 PM
spinedoc
Guest
Posts: n/a
Sick! Did they just drop in with no modifications at all?
Old 24th October 2010, 03:59 PM
Yep
Old 24th October 2010, 05:39 PM
Yep just longer bolts in my case
Old 24th October 2010, 07:37 PM
René René is offline
9,5x20 et36 from the rs6 with 255/35 on it will also fit without any problems
