Old 15th December 2010, 08:47 PM
Saturbo Saturbo is offline
Default Heater Pump Valve - what does it do exactly?
Hoping you folks will be able to help me understand what's going on with my 98 2.8Sport?
I'm getting a buzzing noise from what I think is called the pump valve, just slightly below and to the nearside of the heater/cabin air intake. It will make the noise approx 10secs after turning ignition on - engine doesn't need to be running for it to happen
I followed some of the info from Elsawin and unplugged the unit from the car and sure enough the noise stops (you can actually feel the vibration when it buzzes though). I've been using the car while this is unplugged and doesn't seem any different so I'm wondering what it actually does now?
Am I dmaging something by running without this plugged in? Not throwing any CEL lights etc.
D2 2.8 Sport ('98 110,000miles and counting)
Old 16th December 2010, 10:34 AM
I reacently changed the Pump and valve unit. The pump is only required when you want to heat the car with the engine off. After the water is run up to tempreture, when the engine is switched off,press the button on the climate control and the pump will circulate water through the heater matrix until it gets cold. When the engine is running water is forced through the heat exchangers by the water pump.
Old 16th December 2010, 11:57 AM
thanks Conan - I didn't think it was very important
Any idea how much a replacement one would cost?
Old 28th January 2013, 05:30 PM
Mike, I'm just curious how difficult is to change it.
