Old 30th December 2010, 10:37 AM
Default Odd Braking Feeling...
... in the last couple of days, when I've first taken the car out (this morning and yesterday afternoon) the brakes felt a bit like the servo wasn't working. I had to press the padal very hard and still got little braking effect. But after 100 yards or so, trying the brakes a few times, everything returns to normal. It's a 2002 S8 BTW.
It's not cold here anymore and all the snow has gone, so I don't think it's weather related. Any ideas?
The car is in the garage just now getting tyres on the winter wheels and having the self-levelling headlights checked and I mentioned the brakes, but nothing sprang to mind. So if you've been here before, perhaps you'd point me in the right direction?
Old 30th December 2010, 12:58 PM
My first thought is a vacuum leak to the servo; or the servo is failing.
Old 30th December 2010, 01:52 PM
But why would it get better after a couple of minutes?
Old 30th December 2010, 04:22 PM
Maybe an ABS related issue? Pump not activating properly, causing hard pedal, then once it gets through its self test, it comes back to life?
I assume nothing's come up on the scan?
Old 30th December 2010, 04:39 PM
Could be Richard. Maybe an output test with VCDS on the ABS system will show something.
Old 30th December 2010, 08:26 PM
Nothing obvious from the garage inspection other than the pads are really mucky with salt and grit. Only done 10 miles since I finished work a few days before Xmas, so maybe all the c**p from the roads has caused a film on the pads/discs? And nothing on the self-levelling headlamp arms either. Gonna call A4Audi to see if they can do a scan tomorrow....
