Old 17th March 2011, 08:08 PM
Default New MOT regs ban aftermarket HIDs ?
Its not the first time I've heard this either.
Also under the spotlight seems to be engine chipping...
anyone heard anything similar?
http://www.vxronline.co.uk/forum/sho...-Remapping-etc
Old 17th March 2011, 08:34 PM
The last time this came up, from memory, not much applied to passenger cars but to larger/heavier vehicles instead, from looking at the EU legislation.
We have quite a lot of scope to interpret in the UK regs - but the golden rule here at the moment is to avoid 'gold plating' implementation of EU rules, irrespective of whether it's a 'good thing' or not.
I would expect elements where there have been concerns raised before (e.g. retrofit xenons where an H4/H7 bulb should be for dipped beam in a reflector light unit) to eventually find their way into the UK test. Bare in mind that this could potentially just become another item along with that missing catalytic converter that needs fitting 1 day a year!
The ECU chipping element sounds unworkable for existing cars - too much kit required for too little justification. It's not illegal to chip a car in the UK - some countries require certification of emisions etc if you do, but that's never been the case here.
Whatever happens you can be sure the UK won't implement until the latest possible date given in the EU Directive.
Adrian
Old 18th March 2011, 11:11 AM
jayzee jayzee is offline
As Adrian says, there's been talk about this for years.
Will they enforce it any time soon? I doubt it.
Yeah baby!!
