Old 2nd April 2011, 06:36 PM
brownridge's Avatar
brownridge brownridge is offline
Default Concert- Bose or not Bose?
Had the usual volume issue with my Concert, so I bought a s/h unit on eBay. Slotted it in- all well, everything worked- except that the display didnt say BOSE when you turn it on and the sound is really headbangin bassy!
Leads me to believe that there are two versions of the Concert- one for Bose units and one for not? (having done some surfing of Google- It looks like VAGCOM can enable the BOSE part- anyone know if thats right?)
Also- has anyone had any success in fitting the Concert 2 radio in place of the concert 1?
thanks allan
1998 S8 Silver with Black, Solar roof, blinds, BOSE- who needs gears anyhow!
2001 Jeep Grand Cherokee 4.7 V8
2010 Buell Ulysses XB12XT- the final edition
Old 2nd April 2011, 06:57 PM
As per Brian's issue with a used RNS-D I suspect this is just a coding issue (his was the other way round!) so a bit of time with the necessary software will get it sorted.
Post where you are and I'm sure there'll be someone local to you
Old 2nd April 2011, 07:35 PM
brownridge's Avatar
hi- I am at Newbury
Old 2nd April 2011, 07:36 PM
Yup, it'll just be the software coding on the unit.... A quick tickle with vagcom should have her sorted.
Old 2nd April 2011, 07:45 PM
brownridge's Avatar
Fab- thanks both!
Old 2nd April 2011, 07:50 PM
I'm at Swindon & Oxford during the week so might be able to get across to you or meet up somewhere, Ive got a Vagcom lead & laptop we can use.
Old 3rd April 2011, 09:09 AM
brownridge's Avatar
Thanks very much for the offer. As it happens the car is booked into the specialists who take care of it in Basingstoke on friday 8th as I am starting to have the dreaded lock up "thump" in the gearbox (Ouch!).
So- following the sage advice on this and other sites, its going in for the full Audi oils/filter change in a desperate hope that this avoids a gearbox change. I also have the passenger seat sensor issue- so I am trying out the resistor under the seat solution.
Assuming all goes well, I just have to sort out the two front Chinese tyres ( why do people put cheap tyres on a S8?) and the corrosion on the OE rims- oh, not forgetting the cheap front discs (why do people.......oh never mind!!!)which have now slightly warped.
Audi S8- never short of a project!
Old 3rd April 2011, 10:04 AM
Not sure buddy, nothing but the best (matching) tyres all round for my car and a good brake setup. Skimp somewhere else, not the stuff that connects you to the road and stops you is what I always say.
Old 3rd April 2011, 08:41 PM
Night Train's Avatar
I'd second that Amar....
Other vehicles
Oh Yes....... The '98 PF S8!
Old 4th April 2011, 05:57 PM
Am I wrong in thinking that Quattro needs you to have matching tyres, with matching (as far as you can) wear on each corner. Or you'll stuff the transfer boxes.
Apart form that. Yes Amar summed it up nicely.
What's the point in saving a few quid in your pocket, if you don't have a leg to hang it on
