Old 4th April 2011, 11:45 PM
denkas8 denkas8 is offline
Location: ayamonte, spain, southern border right next to portugal
Default abs and exclamation mark
hi all, abs and exclamation mark lights turn on for a couple of seconds when i step on the gas pedal, happens often on the motorways.
they stay on for a couple of seconds, then switch off.
brakes seem to be alright.
had the car checked a couple of weeks ago and there were no probs.
any suggestions?
s8 d2
Old 5th April 2011, 06:30 AM
Dionysios,
Do you have ESP? If so, switch it off and try accelerating hard to see if you get the ABS light flashing again.
A scan with VCDS would also help.
Old 5th April 2011, 03:12 PM
mikes2 mikes2 is offline
Not sure if the S8 is the same, but on a friend's S4, the MAF caused this fault
Old 10th April 2011, 11:29 PM
RanjS8 RanjS8 is offline
Default abs !!!
A failing maf caused this on my s6....
If you have vag com...test the maf....
the test is.....with engine idling....rev the engine up to about 5000 rpm....there should be a proportional increase in the values of the maf reading...if it falls aways then you know the maf is faulty....
Old 4th June 2011, 08:42 PM
My S8 also does this, usually passing through about 90mph. Accmpanied by a second or two of roughish running, like a minor misfire.
What's the MAF?
Old 4th June 2011, 09:44 PM
It's the Mass Air Flow meter.. It's between the air filter and the engine.
90 mph? I assume that's on a track *ahem*
Old 5th June 2011, 10:37 AM
ermmm...........natch!
Tends to do it only once per outing, usually during the first transition from 'normal' to 'warp drive'.
Old 26th June 2011, 08:43 PM
Fitted new MAF as car running like a coo after being serviced. Prolly fitting the new air filter disturbed a faulty MAF.
Purring like a kitten now.
ABS and exclam mark no longer appear, so looks like MAF was the culprit all along.
Cost was £65. Easy to fit.
