Old 6th May 2011, 01:57 PM
ulfilias ulfilias is offline
Default Aircon - 00792 - A/C Pressure Switch (F129)
Hi There,
Was just checking the codes and this came up. Its only the start of the warm weather and I had been noticing the aircon not working well.
Ross tech has
http://wiki.ross-tech.com/wiki/index.php/00792
Last year I regassed the system
http://forum.a8parts.co.uk/showthrea...ghlight=aircon
The preasure check it by holding a vacuum and it did that no problems. No one has really been near the system since and it was working fine last year. A leak isn't imposible, but i'd guess unlikely.
So i'm guessing a switch. Any idea on where etc. or other ideas
Ta,
A rather warm Lee
Old 6th May 2011, 04:02 PM
The only way to check the switch is to make sure the system is up to pressure then measure the resistance on the switch. The switch allows the compressor clutch to engage if the system is at the right pressure and the compressor is required to run. If the switch is not allowing the magnetic clutch to operate, (you can test the operation of the clutch in the output test in VagCom in the HVAC section) it's either because there is no pressure of the switch is duff.
Old 6th May 2011, 04:09 PM
Any idea how to opperate the clutch in vagcom. I have an old dodgy ebay one, but it seems to work quite well !
The error is Intermitent and Short to B+ if that helps ???
Old 6th May 2011, 08:25 PM
I'll post a screen shot tomorrow with a wee how to.
Old 10th May 2011, 07:56 AM
Hi Conan,
Did you manage to get a screen shot ???
Ta,
Lee
Old 10th May 2011, 08:14 AM
oooops sorry forgot. I'll go out and do it now.
Old 10th May 2011, 08:38 AM
Here we go. Open VCDS to the HVAC page and select button 03 (bottom of column 3). You'll see this:
Hit start and cycle through the tests and you will see this:
Once all the tests are complete check the faults section to see if any registered. If there is a clutch fault then it is possible you have a faulty clutch. The other 2 options are low pressure and pressure switch.
ID:	1886   Click image for larger version
