Old 12th May 2011, 09:23 AM
Default How can I snake wire from boot to radio area?
After accomplishing RNS-D to RNS-E upgrade I'm upgrading TV tuner with digital one. This requires snaking new harness from boot to radio area.
I can cut TV tuner harness to ease the job so I can put the wire through tight places without bothering with bulky connector and then solder the connector when done.
I'm worried about D-pillar trim that can only be removed with parcel shelf out. I wonder if I can cut some corners here.
Alternatively, I can try to cut connectors from both ends of existing legacy RNS-D tv tuner harness and just solder new connectors from both ends. However, my 7th sense suggests there will be more wires in the new tv tuner harness...
Any tips about snaking the wire from boot to radio the easy way?
Thanks.
Old 12th May 2011, 10:09 AM
Depends on how thick the harness is.. you could sneak it through behind the rear seat, though it is a little tight and you will get scratched to hell
Old 12th May 2011, 04:12 PM
Cheers PsYcHe, the harness is 4 or 5 mm diameter.
Old 12th May 2011, 04:19 PM
There should be no need to remove the D pillar IIRC.
Remove the back seats, which is pretty easy, and that will give loads of access.
Also, remove the front passenger seat (4 torq + 1 x 17mm seatbelt) and you can get access under the carpet to run it all the proper route.
There are some foam bits over the rear wheel arch that you'll need to remove to get the cable through, but you'd have to do this either way, but I see no reason for remove the parcel shelf or D pillar for this job.....
Study my Rear seat retrofit thread for oodles of photos of where the looms should run, that should help
Old 12th May 2011, 07:13 PM
Night Train's Avatar
\net curtain wire is pretty useful to poke through and then pull wiring through awkward places such as that, used this method to install my retrofit Bose setup....
Other vehicles
Oh Yes....... The '98 PF S8!
Old 13th May 2011, 12:24 PM
Night Train and Ian, thanks for your replies.
Doing the research now for the easiest way.
